2002 auto climate control not blowing
Zakko
Cedar Rapids, IA
2002 Eddie Bauer
Hey folks, I have a 2002 Eddie Bauer with the automatic climate control. I can only get the blower to come on in the top fan speed, high setting.
It seems that if I turn it all the way up to high and then turn the temperature up as well, the blower does slow down a bit, but not much.
I originally thought it might be a resistor problem, but since the blower seems to have the ability to slow down, I'm not so sure. Any ideas?
AC is cold, fan speed seems to be the only issue.
Zakko
Cedar Rapids, IA
2002 Eddie Bauer
Fixed by replacing the equivalent part to the resistor on a non-automatic climate control system. Goes in the same location (behind the glove box) but works differently. Also costs about twice as much ($50-$60). Sorry, I don't have a part # handy.
Zakko
Cedar Rapids, IA
2002 Eddie Bauer
Part # 6L24-19E624-AA
And it's not working again, nearly two years later... :rolleyes:
Zakko
Cedar Rapids, IA
2002 Eddie Bauer
Update: fixed again. Same repair.
1. open glove box
2. push in on the sides of the glove box to release glove box to full open (hanging down)
3. Remove 3 exposed hex head screws to detach glove box
4. Remove 4x4 control module (rectangular box left of center behind the glove box)
5. Remove climate control module (to the left and behind where the 4x4 control module was, 1 hex screw)
6. Disconnect connector from climate control module
7. Connect new module ($50 from my dealer's parts department)
8. Install new climate control module with hex screw.
9. Test climate control functionality
10. Re-install 4x4 control module
11. Re-attach glove box with three hex screws
12. Close glove box
13. Re-test climate control functionality
Total time: ~30 minutes
Cost: $50
S No A/C, Blower - 2002 Ranger A/C & Heater systems - HVAC 0
S Questions: Recharging 2002 XLT AC A/C & Heater systems - HVAC 4
P 2002 XLT a/c quit working A/C & Heater systems - HVAC 4
H 2002 Edie Bauer Explore blower is posessed!! A/C & Heater systems - HVAC 0
J 2002 Exp LTD- A/C leak A/C & Heater systems - HVAC 0
V 2002 Ranger; Help Troubleshoot Why A/C & Heat Blows Thru Defrost Only - No Vents A/C & Heater systems - HVAC 2
I freon leak 2002 explorer A/C & Heater systems - HVAC 0
A I need help finding the 2002 Ford Explorer radio wiring diagram. A/C & Heater systems - HVAC 4
R 2002 Explorer Sport. A/C problems. A/C & Heater systems - HVAC 1
R 2002 Explorer. Blower motor. A/C & Heater systems - HVAC 1
A 2002 Ranger 2.3- A/C gets warm when engine temp goes up A/C & Heater systems - HVAC 0
T 2002 Eddie Bauer. A/C problems. A/C & Heater systems - HVAC 2
M 2002 Ford Explorer. Auxiliary blend door problem. A/C & Heater systems - HVAC 2
R 2002 Ford Ranger 4 cyl no heat A/C & Heater systems - HVAC 0
D 2002 Sport - No Heat A/C & Heater systems - HVAC 16
K 2002 Ranger A/C won't run. A/C & Heater systems - HVAC 1
K Compressor will not turn on. 2002 w/4.6L A/C & Heater systems - HVAC 19
D 2002 Explorer with no air through the vents A/C & Heater systems - HVAC 1
F15E_WSO 2002 Condenser & Drier R&R---need some words please A/C & Heater systems - HVAC 0
F 2002 Ford Explorer Front Passenger side cold/ driver side warm A/C & Heater systems - HVAC 12
A 2002 explorer A/C & Heater systems - HVAC 2
B 2002 Explorer with an A/C problem. A/C & Heater systems - HVAC 1
G 2002 Explorer climate fan only works on low. A/C & Heater systems - HVAC 7
R 2002 Ford Explorer air conditioner problems. A/C & Heater systems - HVAC 2
C 2002 Ford Explorer Eddie Bauer A/C & Heater systems - HVAC 2
M 2002 merc mounty - no air, compresor not moving A/C & Heater systems - HVAC 1
M 2002 EB constant heat coming out floor vent? A/C & Heater systems - HVAC 2
O 2002 XLT air circulation problem A/C & Heater systems - HVAC 0
A 2002 Mountaineer blend door A/C & Heater systems - HVAC 2
D 2002 Explorer - rear heat/ac bangs A/C & Heater systems - HVAC 10
A low side on 2002 explorer A/C & Heater systems - HVAC 1
M 2002 Explorer Eddie Bauer defrost low airflow A/C & Heater systems - HVAC 0
X 2002 xls rear ac upgrade A/C & Heater systems - HVAC 8
C Picture of 2002 AC Low Side Value A/C & Heater systems - HVAC 2
C Fan shuts down when auto is pressed A/C & Heater systems - HVAC 1
C Retrofit auto environment controls A/C & Heater systems - HVAC 0
E Auto Climate Control Memory A/C & Heater systems - HVAC 0
B how to troubleshoot auto temp control A/C & Heater systems - HVAC 0
R 95 Eddie Auto Climate Control A/C & Heater systems - HVAC 2
J Possible to add auto/dual zone to XLT? A/C & Heater systems - HVAC 2
S Free program -Auto AC Advisor A/C & Heater systems - HVAC 1
W 96 Limited Auto climate control HELP please! A/C & Heater systems - HVAC 3
W auto temp control malfunction A/C & Heater systems - HVAC 2
L temporarily lost communication with the climate system A/C & Heater systems - HVAC 1
E Climate Control on Steering Wheel intermittent and crossed behavior. A/C & Heater systems - HVAC 2
W Upgrading Climate Control A/C & Heater systems - HVAC 2
P How to get my climate control to work in 1998 XLT? A/C & Heater systems - HVAC 23
KC90 Climate controllers A/C & Heater systems - HVAC 3
S A/C problems on a 1997 Explorer with electric climate control. A/C & Heater systems - HVAC 2
M another climate control issue.... A/C & Heater systems - HVAC 0
Similar threads
