2002 Eddie Bauer 4x4 explorer
rpcats
Location
Klamath Falls OR.
Klamath Falls Oregon
2002 E. B. Explorer 4x4
I'm experiencing hard shifts....seems if I let off on the gas pedal it shifts... I did read in the owners manual that if and when you have to replace the battery ...the transmission has to relearn the shifting technique...does anyone know this to be true or am I dealing with something else....like a plugged up vacuum module...also it has a 6cyl , automatic tranny , 4x4
974X4BLACKSPORT
Location
FL
hudson
BLACK 1997 SPORT 4 BY 4
Yes, on the computer re-learn after disconnecting the battery. There is no vacuum module on the transmission, it's all electronic. I would however get a scanner and check for any stored transmission codes, hard shifts can indicate the ECM/PCM is commanding max line pressure due to slippage, (indication by shifting only when lifting the accelerator).
Mike65
Location
In my garage working on one of our vehicles.
Toms River, NJ / Horsepasture, Virginia.
00 Ranger 4x4, 99 Sport.
Welcome.
rpcats
Location
Klamath Falls OR.
Thanks !!! I will get on scanner tomorrow...again THANKS!!!!
