Scott2008
- December 4, 2007
- Hudson, WI
- 2002 Explorer V8
I'm having an issue with my explorer dying when I come to red lights, or simply while idling. It idles fine, then suddenly it'll try to rev up, shutter a bit then die. As long as I push the gas pedal or am driving normal it runs perfect. Someone said fuel pressure regulator but I cannot find a part for this car nor do I know if it's the issue. Someone also said it could the throttle possiition sensor. Finally, there is no check engine light, so I cannot tell if the PCM is throwing codes. (At least with my scanner). Anyone have any suggestions? thanks!
