ttiwkram
- December 2, 2006
I was recently able to fix my “4 wheel drive doesn’t work” problem thanks to contributors to this site. (Thank you all!) But I found there was no single thread that had all the information I needed, so I decided to add this post to summarize the problem and solution in one place.
Symptoms:
- 2002 Explorer, no 4WD function (electrical or mechanical) whatsoever.
- Vehicle reverted to 2-wheel rear drive and fishtailed on slippery roads.
- “4x4 Low” light (left side of instrument cluster) would illuminate during lamp test at engine start, but “4x4 High” light would not.
- No 4x4-related buttons (4x4 Auto, 4x4 High, 4x4 Low) or associated indicator lights worked.
- All 4x4-related fuses good.
- No trouble codes set in OBD II system.
Diagnosis:
Dead 4x4 Control Module.
Repair:
Replace the 4x4 Control Module as follows:
- Disconnect the vehicle battery.
- Open the glove box. Squeeze its sides toward the center and pull the glove box all the way open so that it flops down and you can see/reach behind it. The 4x4 Control Module will be visible slightly to the left of center.
- Remove the one screw holding the module’s bracket in place. Pull out the module along with the bracket. (You now have access to both screws that hold the module to the bracket.)
- Remove the two remaining screws and unplug the two wiring connectors from the module.
- Installation is the reverse of removal. When you reconnect the battery, don’t be surprised if you hear some clicking and buzzing from the general area of the module for 45 seconds or so. I think this is just the module introducing itself to the other computers and/or actuators.
Parts Source:
Original part numbers vary (as do the replacement parts), so when you go looking for a new part be sure to have your original part number and vehicle identification number so your supplier can translate them and find the correct new part.
I got my new 4x4 Control Module for $173.15, shipping included, from my new best friend: Ed Olson at Millennium Ford in Seattle, Washington, 1-800-562-5250. Ed’s email address is parts@millenniumford.com.
Possible pitfalls:
1 - The 4x4 Control Module is not to be confused with the “Powertrain Control Module” (formerly and more accurately known as the “Engine Control Module”).
2 - Some dealers will be glad to charge you $400 for so for the module, and an extra $225 for the ten-minute installation. The common claim is that the module has to be programmed, and that justifies $1,350 per hour. Hogwash! The module screws and plugs right in, and automatically does its own handshaking at power-up.
3 - Don’t use the Haynes manual (#36025) for 2002 - 2003 Ford Explorers. The folks at Haynes are clueless with respect to 4WD -- They don’t even know the 4x4 Control Module exists!
Possible Long-Term Solutions:
1 - Hopefully, the replacement parts will prove better than the originals. There have been many reports of modules failing after a vehicle’s battery was replaced. In my case, we didn’t replace a battery, but we did jump-start the Explorer once. In either case, it’s evident that power surges fried the modules because Ford provided frail and feeble electronics for service in an electrically hostile environment.
2 - In order to absorb future power spikes, I added a 2,200 uF capacitor in parallel with my vehicle’s battery. I don’t know if it will do enough good, but so far it hasn’t done any harm.
3 - No more post-1975 Fords for me. ;-)
Symptoms:
Diagnosis:
Repair:
Parts Source:
Possible pitfalls:
