Emergency Brake woes on 2002 Explorer 4WD
Don't bother with opening up the 'knockout plug'- you cant get to it from the back anyway(at least on 4WD and RWD Explorers!). You really have to take the caliper and the rotor off to adjust it. BUT, if you have driven the car a couple of years since your last rear wheel brake job... ***eddaboutit. that disk aint coming off.
When I did this job the first time, the brake linings were non-existent, just naked shoes. I had never seen that before. So I put all new parts on and tried to adjust them with a little drag (as recommended) and buttoned them up. My daughter (it's her Explorer) complained from the start that there was no ooomph in the parking brakes, so I readjusted them with a little more drag. Not much improvement. I felt that if I made them any tighter they would heat up, wear out, and give her lousy gas mileage.
Two years went by. The rear disk pads are still fine, but I decided to take one more shot at tightening the emergency brake shoes. Well, despite their ineffectualness, they
have worn a groove in the drum and the disk-drum will not come off. The first time I had tackled this job 2 years ago I bent the E-brake shoes getting the Rotor/drum off, so I gave up.
This is a terrible example of engineering, and its sad because none of the technology is very new. We've been putting drum brakes inside disk rotors for years. Why is it so hard??
(This is not so much for the OP, but for future generations of Explorer owners)
Thanks for reading.
