I just bought a 2002 V8 Explorer. The climate fan will only blow out air on low speed. When I turn it up to high it sounds like it's blowing but no air comes out. I had a similar problem with a 2001 Taurus. Replaced the blower motor resistor and it corrected the problem. Is it the same fix? If so where is it located? Is it still behind the glovebox? Thanks.
