2002 explorer idle shaking | Ford Explorer Forums - Serious Explorations
zfish05
park city, utah
2002 ford explorer eddie
My 2002 explorer just started shaking while idling. Then when you push the gas it almost sputers a little bit. Higher rpms i dont notice. Just at idle and very low speeds. Any suggestions?
Which engine? Either way, start by checking the idle air control valve. (IAC)
http://www.explorerforum.com/forums/showthread.php?t=339793
This ^
I had a dirty IAC and when very cold out, it wouldn't really hold idle. After about 15 minutes of driving, the motor would come to life and run normal again.
If that's not the problem, then either new plugs/wires (4.0) or new plugs or COPs (4.6). Could be the MAF sensor too.
More info on motor and the issue will help narrow down possible causes.
