2002 Explorer - Replace Thermostat Housing and Hoses
BiggestWrenchMonkey
2002 Ford Explorer XLS
Hey all,
I have been tasked with trying to repair the coolant leaks coming from the vehicle. From the pictures you can see that I need to replace both the thermostat as well as the housing that it is in. I was recommended the Four Seasons thermostat housing from the mechanic and wanted to know if this is one that would also be recommended on here. I am having trouble figuring out the name of the hoses that I would need to replace. The smaller one seems to be around 7 inches in length and the one feeding directly to the housing seems to be around 20 inches, give or take. I was also wondering if the lower part (which I circled) that is connected to both these lower hoses needed to be replaced as the leaks are around where they meet but seem to come from the hoses themselves. I would appreciate any info and/or links that you could provide me. Thank you in advance.
http://imgur.com/a/FilJC
fordysenior
True Northern California
2002 Expl 4x4 XLT 4.6L
which engine?
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
I just used the Dorman brand thermostat housing. I went with after market hoses (Gates, top of the line) and wouldn't do that again on the V6. Get your hoses from the dealer, as long as they aren't cut-to-fit.
The hoses on the tstat were a lil tricky.
BiggestWrenchMonkey
Thanks, I'll look into getting that tstat housing. From the recommended repairs paperwork I am seeing that the autoshop was planning on using a Dayco brand hose so I will have to get in contact with an actual dealership to see if they have the hoses I need. Thanks again.
