2002 explorer XLS Flex Fuel Turns Won’t Start
Josh Decker
Hartland, mi
2002 Explorer 4x4
I am hoping for some help identifying where to gonext. My wife's '02 Explorer (V-6 with Flex Fuel engine, car manufacture date is March '03), wouldn't start up this afternoon. She drove it earlier, no problem. This afternoon she got in to go, and it turned over, no problem, but it would not start.
I've checked the batter, 12.4V before I started messing with it. It has no codes coming off on my code reader (not scanner). I tried shifting into neutral and back into park to make sure that wasn't an issue. The anti-theft lift lights up when I turn the key to "on" and then goes out.
We typically run E85 through the fuel system. I went to try to check the spark plugs, thinking maybe they are fouled, but the boot didn't want to seem to come off. I felt it disengage from the plug, but couldn't get the boot off, and didn't want to damage the plug.
At this point I am thinking one of the following, any help with how to proceed with diagnosing would be greatly appreciated!
  1. fouled spark plugs
  2. faulty fuel pump
  3. [ruled out] fault fuel pump relay
  4. faulty ignition coil
Thanks for the help!
Update: checked the relay with multimeter, checks out ok.
Josh Decker
Hartland, mi
2002 Explorer 4x4
SOLVED: put a couple gallons of gas in the tank, let the fuel pump cycle a couple times and it started right up. Incorrect fuel gauge.
M My 2002 Explorer xls won't start. Stock 2002 - 2005 Explorers 11
D Can’t find a hatch glass! 2002 Ford Explorer XLS Stock 2002 - 2005 Explorers 10
J Fog lights for 2002 Explorer XLS Stock 2002 - 2005 Explorers 3
A How to Drain Fuel from 2002 Explorer XLS Stock 2002 - 2005 Explorers 11
L 2002 Ford Explorer XLS has a Ghost Living in It Stock 2002 - 2005 Explorers 6
E 2002 Ford Explorer XLS heat not working. (Video attached) Stock 2002 - 2005 Explorers 1
L 2002 Ford Explorer XLS Instrument Cluster Stock 2002 - 2005 Explorers 4
L 2002 Ford Explorer XLS Dome Light Stock 2002 - 2005 Explorers 6
E 2002 Explorer, XLS, RWD - Front Hub Replacement ? Stock 2002 - 2005 Explorers 0
S 2002 Explorer XLS 4x4 5spd Clutch - 23 or 26 spline - can VIN tell you? Stock 2002 - 2005 Explorers 8
R 2002 Explorer XLS Air Conditioning Not So Cold Stock 2002 - 2005 Explorers 14
9 A.J.'s 2002 Explorer XLS 5-speed Stock 2002 - 2005 Explorers 9
W 2002 ford explorer xls won't start after stalling it out from improper clutch release Stock 2002 - 2005 Explorers 0
K 2002 Explorer XLS Stock 2002 - 2005 Explorers 3
Z Need help -2002 Ford Explorer XLS will not start. Stock 2002 - 2005 Explorers 2
B New to me 2002 Explorer XLS has "Auto 4x4" button on dash......is it true 4WD? Stock 2002 - 2005 Explorers 2
W 2002 explorer xls no heat out defrosters Stock 2002 - 2005 Explorers 2
L 2002 explorer xls Stock 2002 - 2005 Explorers 2
V 2002 Explorer XLS Stock 2002 - 2005 Explorers 2
F 2002 explorer xls issues and questions Stock 2002 - 2005 Explorers 9
D Will 2005 Cargo Security Shade fit 2002 Explorer XLS? Stock 2002 - 2005 Explorers 4
J I need to replace the spark plugs & wires on a 2002 Explorer XLS. Stock 2002 - 2005 Explorers 6
S 2002 Explorer XLS Headlight/Hi-Beam issue Stock 2002 - 2005 Explorers 1
D 2002 explorer sport and 4dr xls parts compatability Stock 2002 - 2005 Explorers 0
N Best Firestone Tire for 2002 Explorer XLS - On road only Stock 2002 - 2005 Explorers 11
W 2002 Explorer XLS Wheel Bearing Stock 2002 - 2005 Explorers 4
M 2002 Ford Explorer XLS Engine Issues... Stock 2002 - 2005 Explorers 12
E Replacing keyless transmitter on 2002 Explorer XLS with fusion key Stock 2002 - 2005 Explorers 2
J Increased RPM on 2002 Ford Explorer XLS Stock 2002 - 2005 Explorers 1
E Explorer xls 2002 transmission Stock 2002 - 2005 Explorers 8
W 2002 Explorer XLS rear disk brake dragging Stock 2002 - 2005 Explorers 4
S Please Help, 2002 standard 4x4 explorer wont go into gear when started Stock 2002 - 2005 Explorers 9
KA3NXN 2002 4.6 Explorer has low power and bucks between 40-50mph Stock 2002 - 2005 Explorers 2
Z 2002 Ford Explorer ABS light comes on and off pulsating brakes Stock 2002 - 2005 Explorers 0
S 2002 Explorer Coolant question Stock 2002 - 2005 Explorers 1
L Rims from 95 Explorer 4wd EB onto 2002 Explorer 4wd EB Stock 2002 - 2005 Explorers 7
S 2002 Explorer Oil Pan replacement Stock 2002 - 2005 Explorers 5
J Need a little help fight in the condensation drain on a 2002 Ford Explorer XLT Stock 2002 - 2005 Explorers 0
N 2002 does explorer xlt transmission help Stock 2002 - 2005 Explorers 0
S Unknown connector behind the manifold 2002 XLT V8 4.6L Explorer Stock 2002 - 2005 Explorers 4
M 2002 Explorer Sport 4WD 2 door Stock 2002 - 2005 Explorers 0
B 2002 Explorer Rear Camber Issue Stock 2002 - 2005 Explorers 12
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
E Hey everyone! 2002 Ford Explorer tire options? Stock 2002 - 2005 Explorers 9
S Will 2000 fit 2002 transmission explorer Stock 2002 - 2005 Explorers 1
I 2002 Explorer won't turn over Stock 2002 - 2005 Explorers 8
J 4x4 Problems on 2002 Explorer Stock 2002 - 2005 Explorers 7
J 2002 Ford Explorer 4.0 Stock 2002 - 2005 Explorers 4
B 2002 Explorer: How to remove cabin fusebox? Stock 2002 - 2005 Explorers 2
M 2002 Explorer 5R55W Trans Won't Go Into Any Gear, No Codes Stock 2002 - 2005 Explorers 1
Similar threads
