2002 Ford Explorer 5R55W Transmission Question?
chris288
TN
2002 Ford Explorer
Well I am a new member and this is my first post. Sooo glad I found this forum. Well here is what the issue is and what I have done so far....
From 3-4 its the typical rev up to 3-4k RPM and once I ease off the gas it will engage into OD. The OD light flashes, Check Transmission comes on and Check Engine has come on.
It kicks into Limp mode until I shut it down. I have tightened the band.. (which is still has some slack BTW) and replaced the Solenoid pack.
Its still doing the same thing. Seems to get worse when I have test drove it a few miles, then shut it down and it seems to not rev as high to engage.
Should I try to the servo Boro pin fix? I am not a transmission specialist. Ironically, I am selling it in March to buy another later model one because with my job I put tons of miles on it.
What would you guys do at this point? Used Transmissions (if its even that) are 1k plus labor.
I would like a temp fix for a few months, but hearing horror stories of spending 3-4k at the dealer and the problem comes back in a couple weeks.
What do you guys suggest I could try that is inexpensive? Or anything I could check? What else could cause this that is not mentioned above?
Can I use something like a Lucas Transmission liquid that is heavier if the Servo Boro is worn and its letting fluid through? Will a thicker fluid help?
Thanks for any advice?
chris288
TN
2002 Ford Explorer
Thanks Tony.. I appreciate it.
S 2002 Ford Explorer Transmissions & Transfer Cases 2
M 2002 Ford Explorer Transfer case housing gasket. Transmissions & Transfer Cases 9
O 2002 ford explorer v6 xlt drivetrain thumping Transmissions & Transfer Cases 0
0 2002 Ford Explorer started slipping. How long could it run before it's dead? Transmissions & Transfer Cases 7
J 2002 Ford Explorer Sport - Potential Transmission Problems Transmissions & Transfer Cases 1
S 2002 Ford Explorer 4x4 4.6L automatic Transmissions & Transfer Cases 1
9 2002 Ford Explorer Eddie Bauer V8 Transmission Problems Transmissions & Transfer Cases 2
M 2002 Ford Explorer XLT P0775 error.. no check engine light Transmissions & Transfer Cases 20
B 2002 Ford Explorer 4.6 won't shift out of 1st Transmissions & Transfer Cases 0
U 5R55W -2002 Ford Explorer - Servo Replacement Saga. Transmissions & Transfer Cases 29
B 2002 Ford Explorer 4.6L v8 NO 4 wheel drive Transmissions & Transfer Cases 2
S 2002 ford explorer V8 vibrating noticbly at the light Transmissions & Transfer Cases 13
A Transmission Issues in a 2002 Ford Explorer Transmissions & Transfer Cases 1
J 2002 Ford Explorer making grinding noise when coasting Transmissions & Transfer Cases 18
F I need help with the rear differential on my 2002 Ford Explorer. Transmissions & Transfer Cases 1
P 2002 Ford Explorer XLT with a flashing O/D light. Transmissions & Transfer Cases 52
S 2002 ford explorer not working Transmissions & Transfer Cases 2
L 2002 Ford Explorer transmission leak. Transmissions & Transfer Cases 4
T 2002 Ford Explorer transmission problem. Transmissions & Transfer Cases 3
D 2002 Ford Explorer Parking sensor Transmissions & Transfer Cases 1
D 2002 Ford Ranger Edge No Reverse Drives in Neutral Moves Forward 2 ft in Reverse Transmissions & Transfer Cases 6
J 2002 ford ranger trans pump Transmissions & Transfer Cases 1
D 2002 Transmission Transmissions & Transfer Cases 1
1 2002 Explorer 4x4 not working Transmissions & Transfer Cases 2
P will 2002-2005 front/rearends fit 2006+ Transmissions & Transfer Cases 0
C 2002 explorer p0741 code. 5r55w transmission problems. OD light flashing. Transmissions & Transfer Cases 2
T 2002 Explorer with a broken servo piston in a 5R55W transmission. Transmissions & Transfer Cases 4
S New to this forum. 2002 tranny issues Transmissions & Transfer Cases 1
S 2002 Explorer Transmission Headache Transmissions & Transfer Cases 1
S 2002 explorer Eddie Bauer 4x4 control module Transmissions & Transfer Cases 0
I 2002 v8 auto transmission behind a 4.0? Transmissions & Transfer Cases 2
P 2002 mountaineer tranny issues Transmissions & Transfer Cases 0
T 2002 Explorer 4x4 not working Transmissions & Transfer Cases 23
E 5r55e Sensor Confusion on 2002 Mazda b4000 Transmissions & Transfer Cases 2
J 2002 Mercury Mountaineer Tranny Swap Transmissions & Transfer Cases 17
S 2002 Explorer XLT O/D Off Light Flashing Transmissions & Transfer Cases 1
B 2002 Explorer 2WD Transmission Worries Transmissions & Transfer Cases 2
P 2002 explorer flashing 4x4H light and no 4x4 Transmissions & Transfer Cases 0
M 2002 Explorer 4x4 Help Transmissions & Transfer Cases 0
Dre 2002 Explorer - 4X4 does not work Transmissions & Transfer Cases 4
K 2002 4WD auto tranny trouble going into gear when shifting, noises, and flashing O/D Transmissions & Transfer Cases 6
7 2002 Ranger Transfer case front output seal Transmissions & Transfer Cases 0
P 2002 Explorer XLT Trasnfer Case locked in 4WD Transmissions & Transfer Cases 1
1 2002 Sport Trac transmission doesn't want to go forward. Transmissions & Transfer Cases 2
G 2002 explorer tranny help please Transmissions & Transfer Cases 9
V 2002+ explorer center section removal? Transmissions & Transfer Cases 1
B 2002 Explorer 4x4 low works, 4x4 high doesn't Transmissions & Transfer Cases 0
J 2002 p1812 4x4 flash lighting Transmissions & Transfer Cases 0
V 2002 Explorer Sport Trac Transmissions & Transfer Cases 0
R 2002 4.6 4x4 with codes P0735 and P0775 Transmissions & Transfer Cases 6
Similar threads
