mckeymouz
- October 26, 2013
- Lousiana
- 2002 Explorer
I have a 2002 Ford Explorer and my climate control switch (the one that changes from air conditioner, defrost, heat, etc) would only blow out of the A/C vents regardless of what was selected.
After a visit to a mechanic (who quoted me over $900.00 to fix), multiple visits to the parts store (all recommended replacing the actuator) and hours on google/you tube. I was at a loss. I did not want to have to remove the dashboard.
Luckily while checking under the dash, I spotted a small broken plastic lever. When I switched the climate control switch, I could see the vacuum "piston" did indeed work, but the lever was broken.
After multiple attempts with twist ties (thanks to google search), some washers and nuts... nothing seemed to work. Finally, I used a piece of foam roofing insulation to "transfer" she shape of the plastic (see photo). Using this, I took a piece of sheet metal and cut out a replacement piece. Additionally, I cut out a small piece for the back (note the slot to accommodate the plastic piece in the back).
Then, using a 1 1/4" nut and bolt I assembled it back together. everything works fine now! (Except my knuckles... they are rather scratched up from the tight space!)
