JoeCool6972
- November 16, 2008
- where ever I may roam...
- 2007 Sport Trac XLT
Supposedly the bed cover helps improve mileage.
The result came out to 34.5733042 miles to the gallon.
It seems almost impossible, but at 60 miles an hour, my RPMs literally sit at 1,500 rpms.
Unless you have a MPG computer that told you 34.5mpg there is no way you are getting that.
I say the issue is at the gas pump. You probably pumped in less fuel than you used due to the tank being nearly full anyways. A slightly smaller amount pumped in on such a short trip will bump the MPG up considerably.
What is your rear axle ratio and tire size? 1500 rpm is way less than stock for 60 mph. For a 3.73:1 rear axle ratio and P235/75R15 tires 60 mph equates to 1951 rpm. I doubt that your SOHC engine has enough torque at 1500 rpm to sustain 60 mph. I suspect that your speedometer and/or tachometer are/is inaccurate. If your speedometer is incorrect then your fuel mileage is probably also incorrect. My stock 2WD Sport only got 23 mpg on the highway. The modfications you've done don't seem adequate for a 10 mpg increase on a 4WD.
Unless you do it a number of times I wouldnt go by what you got just off one tankfull.
For one I have found it hard to always fill my tank to exactly the same point.
Sometimes I can fill it so far up it stays on full for almost 100miles before it moves and sometimes I just cant get it that full no matter how I try.
I didnt even know my Sport holds 17.5 gallons until I read the manual,
The most I have ever put in it was 16 gallons and I thought it was dead empty.
I found to get a real mpg number I have to average the numbers between 4-5 tankfuls
to get a realistic number.
I get 20mpg city/hwy
( bout 50% of each with the hills around my house thrown in for good measure )
in mine in the summer and around 18mpg city/highway in the winter but I typically run
75-80mph on the highway and I have a heavy right foot.
I guess if I wanted 30mpg I wouldnt have bought a 4000lb 4x4
If you are getting 23mpg highway, I say thats a pretty respectable number. Just remember, its a 4000lb brick, it can only do so good, and I say 23 highway is excellent.
I installed the message center on my XLT V8 4x4 and find it to be very accurate. Yes it does go up to a very high MPG when going downhill, but it drops very low when going up the same hill. Its all about averaging. Right now it sits at 16.5 mpg after 2 weeks of 70 highway 30 city driving.
Is this great. Not really. But I know I have plenty of power on tap, an SUV that can carry my whole family(3 small kids and wife), can tow a pretty decent load(think up to 6000lbs), and can handle our winters. Its safe, comfortable and with the MAC intake and cat back, its pretty fun to drive too!
I can live with 16-17 mpg.
