lmarkie74
- April 30, 2017
- Morganton
- 2013, Ford Explorer, XLS
Having a problem with my Instrument Cluster, 1L2F-10849-AH. All these LED lights do not light up: Check Engine, O/D OFF, Park Brake, Door Ajar, Fuel Cap, Air Bag, ABS, 4x4, 4x4 Low. Pretty much not many of them do come on.
There is a self-diagnostic test that will let you check everything. Press Reset and hold. Turn key to Run (Not Start). Wait about 3 seconds and the LED will read Test. Toggle through the tests until you come to "bulb". This will tell you which ones are working.
Here is my question. I came across a procedure for a swap. When you find a cluster with the same part# and change you're LED display to the new one, it should work with the correct mileage. Anyone done this before?
I called a local guy that does cluster repairs. He says you have to have the mileage and the VIN reprogrammed into the new cluster or it will not work. Is this true?
