Livin4Real
- September 16, 2005
- Naptown, IN
- '02 XLS
I noticed a tiny leak a couple weeks ago under my suv when I would fill it with gas. At the same time I started having issues actually filling the tank, the filler hose would back up after a couple seconds of pumping and shut the pump off. So I crawled under and started investigating the leak to find a very rusted fuel filler neck where the rubber hose attaches. I'm assuming it's rusted though and causing a blockage while pumping. I've tried without success to find a 2002 fuel filler neck from somewhere other than the dealership as I prefer not getting raped for a simple fix item. Can anyone out there point me in the direction of an aftermarket fuel filler neck? My local junkyards don't have an 02-05 explorers and I can only find the lower metal filler section online, I need the upper section. My next course of action is to just cut the 2" of rusted out pipe off and put a longer piece of rubber hose on to run up over the unrusted part. TIA for any help.
