I have a 2002 ford explorer. driverside headlight stopped working. I replaced it with a new bulb, but still nothing. I have checked the plug and there is no power. Are there two fuses for the headlights?
Welcome to this forum! I've moved your thread into the lighting section. Do you have an owner's manual? The manual should tell you what each fuse does. You could check each fuse in the panel if you don't have a manual.
