2002 mass air flow | Ford Explorer Forums - Serious Explorations
2002 mass air flow
xartic
Colorado
2014 Explorer Sport
So my mass air flow sensor went out and I have the service engine soon light on, and I was just wondering if the MAF from a 2 gen wouuld fit on my 2002 xls. Thanks
How do you know the MAS sensor has failed?
A check engine light does not = MAS
You have to pull the code to find the computer fault.
Then just because the code is a MAS code does not mean the MAS has failed.
I believe your 2002 MAS has the intake air temp built into it, so no a Gen II (95-01) sensor will not work as far as I know.
i know its the mass air because the entire sensor is broken and when i take the sensor off the computer piece on it is broken and everytime i accelerate it cuts out and sometimes kills my engine
My '99 is has the IAT build into the MAF.
so do you think one from like a 98+ would work, cause i can get a few from some junk yards
