Mussin
- February 24, 2008
- Lima,Ohio
- '02 Mountaineer
Well Ive had no luck with the tranny in my '02 mounty.. The car has 180,000 miles on it and almost 1.5yrs ago the trans went out. I bought a reman unit off of a place that is no longer in business (My luck...) The reman tranny worked great until 2 weeks ago it wouldn't go into 3rd until you let off the gas completely then would slam into 3rd.. I found a guy locally that would rebuild my orig tranny (still had it in my shed) He went through and found a broken 3rd band and torn servo gasket. He said all the clutches looked great so we reused them. He also took the case to get bored and bushed because the servo rod hole had some slop in it. Well he got it all back together and now it has a 2 sec. delay going into reverse and a delay going into 3rd, Almost have to feather the pedal other than that it drives fine??? He tore apart my reman unit today and said the servo rod was broke off and the rod was stuck in the hole.. Do you think the VB or solenoid could have went bad from sitting in my shed for a yr and a half?? We are going to swap the VB and solenoid pack from the reman to the orig trans to hopefully fix the issues of delayed shift into 3rd and delay going into rev..
Any ideas?
THANKS
Any ideas?
THANKS
