2002 Ranger A/C won't run.
kideight
Hey guys, anybody seen this scenerio? Pressure is running high (100 or so) but it won't engage the compressor. 3 people have tried to jump it and it will not jump, however every once in a while it will engage just for a few seconds on its own without jumping just to tease me. When it does randomly engage the pressure runs about where it should, but it usually just runs for 1 or 2 seconds literally. The other day we let the pressure out some and it did actually stay engaged long enough to get some 134a in and blew nice and cold, but now nothing again. With the pressure guage on it and the compressor not running I let the hot air out down to about 25 and that didn't work, but the pressure quickly built back up to 100. Any suggestions?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
S No A/C, Blower - 2002 Ranger A/C & Heater systems - HVAC 0
V 2002 Ranger; Help Troubleshoot Why A/C & Heat Blows Thru Defrost Only - No Vents A/C & Heater systems - HVAC 2
A 2002 Ranger 2.3- A/C gets warm when engine temp goes up A/C & Heater systems - HVAC 0
R 2002 Ford Ranger 4 cyl no heat A/C & Heater systems - HVAC 0
S Questions: Recharging 2002 XLT AC A/C & Heater systems - HVAC 4
P 2002 XLT a/c quit working A/C & Heater systems - HVAC 4
H 2002 Edie Bauer Explore blower is posessed!! A/C & Heater systems - HVAC 0
J 2002 Exp LTD- A/C leak A/C & Heater systems - HVAC 0
I freon leak 2002 explorer A/C & Heater systems - HVAC 0
A I need help finding the 2002 Ford Explorer radio wiring diagram. A/C & Heater systems - HVAC 4
R 2002 Explorer Sport. A/C problems. A/C & Heater systems - HVAC 1
R 2002 Explorer. Blower motor. A/C & Heater systems - HVAC 1
T 2002 Eddie Bauer. A/C problems. A/C & Heater systems - HVAC 2
M 2002 Ford Explorer. Auxiliary blend door problem. A/C & Heater systems - HVAC 2
D 2002 Sport - No Heat A/C & Heater systems - HVAC 16
K Compressor will not turn on. 2002 w/4.6L A/C & Heater systems - HVAC 19
D 2002 Explorer with no air through the vents A/C & Heater systems - HVAC 1
F15E_WSO 2002 Condenser & Drier R&R---need some words please A/C & Heater systems - HVAC 0
F 2002 Ford Explorer Front Passenger side cold/ driver side warm A/C & Heater systems - HVAC 12
A 2002 explorer A/C & Heater systems - HVAC 2
B 2002 Explorer with an A/C problem. A/C & Heater systems - HVAC 1
G 2002 Explorer climate fan only works on low. A/C & Heater systems - HVAC 7
R 2002 Ford Explorer air conditioner problems. A/C & Heater systems - HVAC 2
C 2002 Ford Explorer Eddie Bauer A/C & Heater systems - HVAC 2
M 2002 merc mounty - no air, compresor not moving A/C & Heater systems - HVAC 1
M 2002 EB constant heat coming out floor vent? A/C & Heater systems - HVAC 2
O 2002 XLT air circulation problem A/C & Heater systems - HVAC 0
A 2002 Mountaineer blend door A/C & Heater systems - HVAC 2
Z 2002 auto climate control not blowing A/C & Heater systems - HVAC 3
D 2002 Explorer - rear heat/ac bangs A/C & Heater systems - HVAC 10
A low side on 2002 explorer A/C & Heater systems - HVAC 1
M 2002 Explorer Eddie Bauer defrost low airflow A/C & Heater systems - HVAC 0
X 2002 xls rear ac upgrade A/C & Heater systems - HVAC 8
C Picture of 2002 AC Low Side Value A/C & Heater systems - HVAC 2
D Help on my 1993 ford ranger XLT A/C & Heater systems - HVAC 3
C "Extinct" AC Hoses and AC freon - 1997 Mazda B4000/Ranger A/C & Heater systems - HVAC 6
M 2009 Ford Ranger - A/C not working A/C & Heater systems - HVAC 1
B 98 Ranger Compressor On & Off A/C & Heater systems - HVAC 17
H 1995 Ranger AC A/C & Heater systems - HVAC 0
L Ranger EATC swap complete, only 2 fan speeds. A/C & Heater systems - HVAC 1
D 99 ranger ac problem A/C & Heater systems - HVAC 0
J 2000 Ranger AC help needed A/C & Heater systems - HVAC 1
J 2009 ford ranger son's truck A/C & Heater systems - HVAC 0
A Explorer Air Box into a Ranger? A/C & Heater systems - HVAC 0
2 AC/Battery issues with 2003 Ranger A/C & Heater systems - HVAC 0
R 2006 Ranger Evaporator Leak A/C & Heater systems - HVAC 1
T 2006 Ford Ranger A/C A/C & Heater systems - HVAC 0
2 2007 Ranger ext cab xlt, low heat, a/c just cool, not cold A/C & Heater systems - HVAC 0
S 98 Ranger 4.0l a/c compressor kicks on with heat? A/C & Heater systems - HVAC 4
B 2007 Ranger. A/C-heater problem. A/C & Heater systems - HVAC 3
Similar threads
