2002 Sport Trac No A/C, Radio Not Working, Windows won't work - HELP
karlijo7
2002 Sport Trac
Can someone help me!!! My A/C quit working, then my radio, my windows won't work, and I think the blinkers don't work. Can someone tell me how to fix?
C 2002 4.0 Sport Trac shuts off at low rpms Under the Hood 0
S Stalling 2002 Sport Trac, IAC okay, NO MIL or codes? Under the Hood 6
G 2002 Explorer Sport Trac 4.0 fuel injector "sleeve" Under the Hood 0
C 2002 Explorer Sport Trac Engine Misfire? Under the Hood 5
C Engine oil for 2002 Sport Trac with 100,000 miles Under the Hood 0
B PO-401 2002 Sport Trac Under the Hood 1
R 2002 Sport Trac 4X4 inop Under the Hood 2
R E85 in 2002 Explorer Sport Trac Under the Hood 4
R Poor Gas Mileage for 2002 Explorer Sport Trac Under the Hood 1
T 2002 Explorer Sport turning over but not starting Under the Hood 5
J 2002 Sport Track Heater Control Valve Under the Hood 0
T 2002 Ford Explorer Sport Repair Advice Needed Under the Hood 7
9 2002 Sport, Intermintent no start when hot, cranks, no gas smell Under the Hood 2
M Volant part # for 2002 explorer sport Under the Hood 0
F 2002 Sport front Driveaxle seal question Under the Hood 1
M Explorer 2002 Sport Transmission Flush Under the Hood 0
B 2002 Explorer Sport Alternator and Battery Under the Hood 5
P 2002 RANGER EDGE REG CAB 4X2 3.0L EFI V6 5SPD OD Under the Hood 2
D No Power at all after replacing shift cable, 2002 XLT Under the Hood 4
W 2002 Explorer 4.6L Coolant Runs to Drain Pan Under the Hood 0
C No Shift or Speedometer 2002 Ford Explorer Under the Hood 0
R Will a 98 4.0 block work in a 2002? Under the Hood 4
2 2002 Ford Explorer, 140k miles, 4.0, V6, Rattling as RPMs increase. Under the Hood 0
2000StreetRod How to: 2002 Explorer Radiator Removal/Installation Under the Hood 6
2000StreetRod How to: 2002 Explorer SOHC V6 Front Cover Removal & Install Under the Hood 8
R 2002 explorer timming done but now will only run 5 mins Under the Hood 2
S 2002 XLT Need Help with Spark Plugs :/ Under the Hood 7
R Air not blowing on a 2002 Ford Explorer Under the Hood 1
A 2002 Explore 4.6 power issues Under the Hood 5
C 2002 explorer noise after chain replacement Under the Hood 4
0 High Idle and faulty Temp Gauge on 2002 Explorer 4.6L Under the Hood 3
J 2002 limited door chime Under the Hood 0
W 2002 ranger 4.0 noise from intake Under the Hood 0
R 2002 Ford Sports Trac Idle Problem Under the Hood 7
0 Which 4x4CM module is compatible in my 2002 Eddie Bauer Under the Hood 0
B 2002 Explorer Eddie Bauer AC blows loud and cold, but doesn't comes out weak Under the Hood 1
B 2002 4.0 explorer cam chain guide Under the Hood 3
D 2002 4.0L SOHC coolant sensors? Pic attached Under the Hood 6
J 2002 Explorer coolant temperature issue. Under the Hood 0
S 2002 Explorer Starting/Battery Issue Under the Hood 1
J 2002 Ford Ranger Edge 4.0 Add on Remote start options Under the Hood 3
H 2002 2.3L Not starting Under the Hood 0
D 2002 Explorer hard starting Under the Hood 3
P 2002 Explorer engine and transmission questions Under the Hood 1
S 2002 4.0 sohc rear cassette replacement - availability Under the Hood 1
R 2002 Ranger Temp Gauge Under the Hood 0
T ECU/ECM location 2002-03 Explorer Under the Hood 1
J Can I put a 2002 or newer 4.0 in my 2000 XLT? Under the Hood 5
O 2002 Explorer 4X4 lights flashing Under the Hood 4
F15E_WSO EGR solenoid replacement 2002 Expl V-6; YGTBSM!!! Under the Hood 2
Similar threads
