2002 V8 oil pressure???
daleshopp
lagrange ky
2002 explorer 8 cyl.
suddenly the "Check Guage" light has come on, the guage is at 0 pressure. This is intermittent, and now the guage will not come up. Is this a pressure problem or a guage problem.
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
2001 Sport (sold)
welcome
Dopler174
Official Welcome Committe
Moderator Emeritus
Greensboro, NC
1993 XLT 4X4
I would start by checking the oil. Then the sending unit, (it will be close to the oil filter), then the gauge.
shadowless127
Long Island, NY
'01 EB AWD 5.0
the gauges are dumbie units; they only display 2 positions, off and on.
rocket2ya
PHX
02 mountaineer v8
lol this happened to me and a few days later the engine started knocking. turned out my oil pump went out. i'd get it checked out.
C 2002 Ford Explorer 4.0 SOHC Low Oil Pressure Stock 2002 - 2005 Explorers 8
R 2002 explorer 4.6 timing issues. Losing oil pressure Stock 2002 - 2005 Explorers 3
B 2002 4.6 low oil pressure message Stock 2002 - 2005 Explorers 5
G 2002 V8 oil pressure sender replacement Stock 2002 - 2005 Explorers 8
S 2002 Explorer Oil Pan replacement Stock 2002 - 2005 Explorers 5
W can't find oil dipstick on my 2002 mercury mountaineer 6 cylinder Stock 2002 - 2005 Explorers 4
M 2002 4.0 oil leak Stock 2002 - 2005 Explorers 0
M Rear Gear Oil Question(s) 2002 EB Stock 2002 - 2005 Explorers 2
L slow drip around oil filter 2002 XLT v8 Stock 2002 - 2005 Explorers 5
R 2002 Explorer V6 drips oil on manifold near oil filter Stock 2002 - 2005 Explorers 2
B Do the oil pan gaskets leak on 2002 4.0, or will front main seal fix the oilyness Stock 2002 - 2005 Explorers 2
2 Where are the typical oil leaks on a 2002 4.0 and what's involved in fixing them Stock 2002 - 2005 Explorers 5
2 What woud you consider normal oil seepage/buildup on the bottom of 155K 2002 4.0 XLS? Stock 2002 - 2005 Explorers 2
C 2002 Mercury Mountaineer Engine Oil Leak Stock 2002 - 2005 Explorers 0
S 2002 XLT 4.6L the tranny is leaking oil Stock 2002 - 2005 Explorers 2
A Ford Explorer XLT 2002 Oil engineer Stock 2002 - 2005 Explorers 1
T 2002 Explorer Oil Change Stock 2002 - 2005 Explorers 7
R 2002 4.6L oil in my coolant Stock 2002 - 2005 Explorers 5
R Used oil analysis, 2002 V6 4.0L Eddie Bauer Stock 2002 - 2005 Explorers 3
R 2002 XLT noticed grease and oil on lt. rear hub Stock 2002 - 2005 Explorers 4
S Please Help, 2002 standard 4x4 explorer wont go into gear when started Stock 2002 - 2005 Explorers 10
Z What years 4.6 for a 2002? Stock 2002 - 2005 Explorers 3
KA3NXN 2002 4.6 Explorer has low power and bucks between 40-50mph Stock 2002 - 2005 Explorers 2
S 3rd Gear gone on 2002 4.6 Stock 2002 - 2005 Explorers 4
E 2002 vacuum hose to nothing Stock 2002 - 2005 Explorers 0
Z 2002 Ford Explorer ABS light comes on and off pulsating brakes Stock 2002 - 2005 Explorers 0
S 2002 Explorer Coolant question Stock 2002 - 2005 Explorers 1
W 2002 replacement brake pads & rotor suggestions Stock 2002 - 2005 Explorers 5
G Need to Rent/ borrpw Rear Main Seal Installer 2002 v6 SHOC 4.0 Stock 2002 - 2005 Explorers 5
L Rims from 95 Explorer 4wd EB onto 2002 Explorer 4wd EB Stock 2002 - 2005 Explorers 7
J Need a little help fight in the condensation drain on a 2002 Ford Explorer XLT Stock 2002 - 2005 Explorers 0
S 2002 Expo cooling system boiling and OD OFF light flashing Stock 2002 - 2005 Explorers 11
N 2002 does explorer xlt transmission help Stock 2002 - 2005 Explorers 0
S Unknown connector behind the manifold 2002 XLT V8 4.6L Explorer Stock 2002 - 2005 Explorers 4
J 2002 4.6 V8 Engine Stall and Low Pressure Warning Light Stock 2002 - 2005 Explorers 0
M 2002 Explorer Sport 4WD 2 door Stock 2002 - 2005 Explorers 0
B 2002 Explorer Rear Camber Issue Stock 2002 - 2005 Explorers 12
S 2002 Mercury Mountaineer Stock 2002 - 2005 Explorers 6
T 2002 4.0 SOHC Intake Manifold Sound Deadening Insert Stock 2002 - 2005 Explorers 1
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
E Hey everyone! 2002 Ford Explorer tire options? Stock 2002 - 2005 Explorers 9
S Will 2000 fit 2002 transmission explorer Stock 2002 - 2005 Explorers 1
I 2002 Explorer won't turn over Stock 2002 - 2005 Explorers 8
J 4x4 Problems on 2002 Explorer Stock 2002 - 2005 Explorers 7
J 2002 Ford Explorer 4.0 Stock 2002 - 2005 Explorers 4
B 2002 Explorer: How to remove cabin fusebox? Stock 2002 - 2005 Explorers 2
M 2002 Explorer 5R55W Trans Won't Go Into Any Gear, No Codes Stock 2002 - 2005 Explorers 1
J 2002 explorer XLS Flex Fuel Turns Won’t Start Stock 2002 - 2005 Explorers 1
J 2002 explorer turn signals Stock 2002 - 2005 Explorers 0
M 2002 Explorer new (rebuilt engine) coding P0442 Stock 2002 - 2005 Explorers 7
Similar threads
