jcraft
- July 14, 2011
- Buffalo , ny
- 02 limited
Hi all,
I have a 2003 Ford Explorer limited with 60,000 miles on it. I was looking at the maint. schedule on line and it looks like the transfer case oil does not need to be changed until 150,000 miles unless it is used for extensive periods towing, off roading etc.. I do use it to tow an RV about a half dozen times a year for approx. 50 miles per trip ( this is the first year towing). Not sure if that qualifies for extensive periods. Anyways, can some chime in and let me know how often you change the case oil and if it is easy to do. I also seen in the manual about changing the differential oil as well but is confusing as they state so may variables as to when to change ( such as if you have sythentic- but how do you now what they put in) or if you need to change at all.
