PATS DTC CODES:
PATS Diagnostic Trouble Code (DTC) Index
³ DTC ³ Flashing Fault ³ Description ³ Action ³
³ ³ Code ³ ³ ³
³ B1213 ³ 21 ³ Anti-Theft Number of Programmed Encoded ³ GO to Pinpoint Test B1213. ³
³ ³ ³ Ignition Keys Below Minimum ³ ³
³ B1232 ³ 12 ³ Defective Transceiver ³ GO to Pinpoint Test B1232. ³
³ B1600 ³ 13 ³ No Key Code Received Ä Damaged Encoded ³ GO to Pinpoint Test B1600. ³
³ ³ ³ Ignition Key or Use of Non-PATS Encoded ³ ³
³ ³ ³ Ignition Key ³ ³
³ B1601 ³ 15 ³ Unprogrammed Encoded Ignition Key (Keycode ³ GO to Pinpoint Test B1601. ³
³ ³ ³ Format OK) ³ ³
³ B1602 ³ 14 ³ Invalid Key Code Format From Encoded ³ GO to Pinpoint Test B1602. ³
³ ³ ³ Ignition Key Transponder ³ ³
³ B1681 ³ 11 ³ PATS Transceiver Signal Is Not Received ³ GO to Pinpoint Test B1681. ³
³ B2139 ³ 23 ³ Security ID Does Not Match Between PATS ³ GO to Pinpoint Test B2139. ³
³ ³ ³ and PCM ³ ³
³ B2141 ³ 22 ³ No Security ID Exchange Between PATS and ³ GO to Pinpoint Test B2141. ³
³ ³ ³ PCM ³ ³
³ U1147 ³ 16 ³ Faulty SCP Link or Incorrect PCM ³ GO to Pinpoint Test U1147. ³
³ ³ ³ Calibration ³ ³
