Typically the "Upper Plenum" refers to the intake elbow between the throttle body and the intake manifold.
Performance Products also makes a "typhoon" aluminum intake for the mustan which should bolt right up.
EDIT: Tha would be Proffesional Products.
The pic on the Edlebrock seems to show the fuel rail mounting holes at a 90deg angle to what the Explorer needs. I'm going to have to call to see what's up with that. Maybe they supply a conversion bracket. Or maybe the customer has to come up with some.
tower said:I looked into the Edlebrock one and it seems you need to use new fuel rails and a new upper plenum. Some claim to have used stock parts but had to fab up there own brackets and such. With the new fuel rail you would need to plum in your own fuel lines as they don't come with them. This info is from the mustang guys.
how about this one? pricey though..
http://www.amazon.com/Professional-...002&vehicleType=automotive&newCar=1&carId=002
they also have a chrome finish for an extra $$
MY MOUNTY
http://www.facebook.com/diyfordexplorer?sk=photos
If this was to be fixed by mechanic, how much would one charge to fix this? Reason I'm asking is we have experience some coolant loss and I haven't dug into the engine to find if this is possibly the root cause.
We are trying to sell it and wonder what the cost would be to fix to help with our asking price.
There is virtually no issue for the CATs what so ever if you use straight water as coolant while you troubleshoot the leak.
I've isolated mine and have a temp fix in place now until I have time to implement my plan of removing ALL the plastic between the heads and the metal water tube that connects the two heads.
My temp fix is a clamp. I managed to rebuild the plastic area around the thermostat area. I did this only to make sure I understood where all the leaks were coming from.
They are on both sides where the water goes through. That's whey I'm removing them and going straight to the heads (with a gasket separating them) I have a new intake manifold but am committed to this other solution.
Oh BTW on the passenger side where the leak is, it is aggravated by the fact that there is only one bolt there. I use a clamp as the temp fix.
Works wonderfully. NO LEAKS !!!!
