2003 Explorer, Continuous Water Pump Problems | Ford Explorer - Ford Ranger Forums - Serious Explorations
WoodCJ7
Broomfield, Colorado
2003 Ford Explorer XLS
I am looking for advice on continuous water pump problems, 2003 Explorer, 4L, V6. We are the 3rd owner. Here's some history:
Original Owner Records:
Nov 2004 - Coolant Recovery Tank, Tstat, and Oring Replaced
Nov 2006 - Owner complained of leaking coolant. Pressure tested and found water pump leaking. Recommend replacement of water pump and owner refused.
Jan 2007 - Water Pump Replaced
Apr 2008 - Cooling system flushed, chemically cleaned, pressure tested
2nd Owners Records (Relative):
Apr 2009 - Water Pump, Tstat Replaced
Mar 2011 - Water Pump Replaced
Our Records (We purchased in Nov 2012):
Dec 2014 - Water Pump Replaced
Oct 2015 - Water Pump Leaking - AGAIN!
As you can see there is a history of continuous problems with the water pump. Prior to replacing again, does anyone have any suggestions? Is there something else that has been overlooked?
Thanks for your help!
Number4
"I'm counting to 3, then I'm getting your dad."
Woodstock, GA
04 Ford Explorer 4.6l
Need to know how it's failing. Is it leaking via a weep hole?
Is it leaking at the oring (mounting surface)?
rwt101
pigeon forge tn
2005 Explorer
This is really going out on a limb, but I wonder if the thermostat housing is leaking and maybe running down. towards the water pump and people are getting the wrong diagnoses.
I know that is a little crazy.
Bob T
:usa:
Joe in NY
Binghamton, NY
2002 Eddie Bauer V8 4X4
Also, chemical cleaning? What coolant? Could be destroying seals..
Also, doesn't exhaust gases in coolant make the coolant acidic?
WoodCJ7
It looks as if it's leaking at the seal.
WoodCJ7
As far as the chemical cleaning, I'm reading that from the records of the original owner. I don't have any other details.
Number4
Woodstock, GA
Where it seals against the block?
If it's at the block, remove a bolt, put some blue loctite on it and put it back in. Then move to the next bolt.
First though, hit them all with a torque wrench and see if they've come loose.
It's possible that there's a gouge in the mating surface too.
If it's coming out of the weep hole, it could be that the belt is too taught.
Can you post some pictures of the area where the leak is?
