2003 Explorer Coolant & Heat Mystery!
dsturch1
Pennington, NJ
03 4.0 XLT & 98 5.0 XLT
Anybody with input is greatly appreciated at this point as I am getting extremely frustrated with my truck. I have a 2003 Ford Explorer XLT with the 4.0L 6 cylinder. The truck has been having coolant loss issues for the past month or so and I for the life of me can not figure out what is going on. I have done everything to make sure I keep coolant in the truck as to not overheat.
I had a couple of issues in the past with the truck losing coolant but I have had them since addressed. When this all started last summer, I saw the leak, the trail was evident and the water pump was leaking. I had the issue fixed and the system bled out and refilled with coolant. That water pump then had a defect and was also leaking again. I then had it repaired (under warranty) and everything was back to normal. The second water pump also blew a seal at which point I had that repaired (yet again under warranty) and now I am on the third pump. At the point the third pump was done, I also had them do a thermostat just in case that was also an issue. As I said before, I don’t see any evident leaks of any sort or have any stains in the driveway from losing coolant.
Now recently (a month or so since the last repair) from a cold start the truck will start fine, run fine, etc. and then all of a sudden the temp gauge will rapidly go up and peg at hot, stay for about 5 seconds maybe, and then kick back down rapidly to normal operating temperature. After doing so, it will do this about 2 or 3 cycles typically and then my heat in the truck will get hot and warm up. I am assuming this would either be air in the system, or a bad coolant temperature sensor.
I am also losing coolant rapidly, however I have zero smoking out the back. I filled the system up earlier this week (Thursday) and now on Saturday I am already low on coolant with only about an inch in the overflow bucket. I don’t have any obvious leaks, or any stains in the driveway and haven’t noticed any wet spots underneath the truck or in the engine compartment at all.
From here on out my buddy who is an recently retired Ford mechanic told me a few things to do. First was to change the thermostat to ensure it was actually changed. Second was to drain all of the coolant in the truck at the moment. Third was to refill the coolant myself to ensure it is full. Finally was to replace the overflow bucket cap to ensure its releasing pressure and to make sure I don’t blow seals on that water pump again just in case in the event it was from a faulty cap.
Does anyone have any additional input, help, suggestions, comments, or has anyone heard of any Explorers having similar symptoms and what the outcome was? Thanks for any feedback in advance!
jahzwolf
Seattle
I have just successfully overcome a cooling system MULTIPLE leak issue.
The key is REPLACE the thermostat HOUSING Assembly.. do it now.. that plastic must have sprung 10 leaks i fixed before i finally replaced it.. and when i did looking at the plastic INSIDE the housing I could see clearly why.. the plastic has become crystalized throughout.
on your truck like mine the housing routes the HOT water directly to the heater core and returns to the water pump.. so if using your heater on full makes a difference you may have issues with your thermostat being stuck or your radiator not getting the water cooled down, or the pump not driving the water thru the block..
I would start with the housing assembly. Mine is a 2000 6 cylinder SOHC I would see if you have the same unit or not..
dsturch1
Pennington, NJ
I think I fixed it, the clamp on the lower radiator hose looked like it was kind of loose. I replaced that as well as the thermostat and the gaskets. I let the truck warm up and didn't have a single bit of overheating at all and the heat got hot as soon as the truck read at normal operating temperature.
I took the truck for a good 30 mile ride just to let it run at temperature, burp out any air in the system hopefully, and see how it was. The truck never read anything above normal operating temperature and the coolant level only dropped maybe a quarter of an inch on the overflow tank. Keeping my fingers crossed.
J 2003 Explorer coolant hoses Stock 2002 - 2005 Explorers 1
S 2003 Explorer Sport Trac Coolant Leak Stock 2002 - 2005 Explorers 4
E 2003 explorer xlt coolant leak question Stock 2002 - 2005 Explorers 2
S 2003 Explorer 4.6L Coolant in Oil Stock 2002 - 2005 Explorers 5
S 2003 Explorer 4.6L Coolant Loss Stock 2002 - 2005 Explorers 35
R Missing coolant on a 2003 Explorer. Stock 2002 - 2005 Explorers 2
E 5r55s 2003 explorer year interchange Stock 2002 - 2005 Explorers 1
S 2003 Ford explorer xlt quarter window glass Stock 2002 - 2005 Explorers 0
S 2003 ford explorer charing issue fusable link replacement? Stock 2002 - 2005 Explorers 1
G OEM electric fan on 2003 explorer sport Stock 2002 - 2005 Explorers 1
C 2003 Engine Swap To 2005 Ford Explorer Swap Stock 2002 - 2005 Explorers 5
S Hi im shawn trying to figure out the rumbling sound from breather box 2003 ford explorer xlt Stock 2002 - 2005 Explorers 2
W 2003 Ford explorer misfire Stock 2002 - 2005 Explorers 1
P 2003 Ford Explorer auto trans Stock 2002 - 2005 Explorers 2
F 2003 explorer won’t start Stock 2002 - 2005 Explorers 4
G 2003 Explorer sport 2dr 4wd Leaf spring Stock 2002 - 2005 Explorers 3
A Advice on Transmission, possible failure - 2003 Explorer 4.6 L V8 Stock 2002 - 2005 Explorers 12
J 2003 ford explorer xlt windows not working Stock 2002 - 2005 Explorers 4
M Is there a market for a 2003 Explorer? Stock 2002 - 2005 Explorers 3
2 Please Help - 2003 Ford Explorer Won't Start Stock 2002 - 2005 Explorers 5
D 2003 Explorer Eddie Bauer Aftermarket parts Stock 2002 - 2005 Explorers 1
0 2003 Explorer XLT V6 Rear End Stock 2002 - 2005 Explorers 4
M 2003 explorer 4.6l exhaust leak Stock 2002 - 2005 Explorers 0
S 2003 ford explorer for overheating Stock 2002 - 2005 Explorers 8
S 2003 Explorer Gear Shift Indicator Broken Stock 2002 - 2005 Explorers 4
J Vacuum issues with 2003 Explorer (K Motor Flex Fuel) Stock 2002 - 2005 Explorers 0
W swapping a 2004 explorer transmission in a 2003 Stock 2002 - 2005 Explorers 2
D Electrical Issue to Starter 2003 Ford Explorer Stock 2002 - 2005 Explorers 4
F 2003 Explorer squeal with right turns only (sounds like brakes) Stock 2002 - 2005 Explorers 22
B 2003 Explorer with DTC P1780 & P0775 & O/D flashing. Stock 2002 - 2005 Explorers 23
0 2003 Explorer XLT Blend Door Change-out Stock 2002 - 2005 Explorers 3
E 2004 Explorer (2003 SOHC) "death rattle" Stock 2002 - 2005 Explorers 28
L Wiring Diagram 2003 Explorer (Wiring around steering column) Stock 2002 - 2005 Explorers 0
L 2003 Ford Explorer/Remove and Replace Steering Column-HELP Stock 2002 - 2005 Explorers 1
R 2003 Ford Explorer ignition wiring diagram. Stock 2002 - 2005 Explorers 0
J Replacing a 2003 explorer radiator, nightmare! Stock 2002 - 2005 Explorers 2
E What were the rear end ratios on 2003 Explorer with 4.6 v8 Stock 2002 - 2005 Explorers 3
2 2003 Ford Explorer Heated/Memory Seats Problem Stock 2002 - 2005 Explorers 1
F 2003 Explorer 4.0 spark plugs Stock 2002 - 2005 Explorers 40
R 2003 Explorer XLT won't move Stock 2002 - 2005 Explorers 5
D 2003 Explorer Stock 2002 - 2005 Explorers 1
A 2003 Explorer Crank Issue Stock 2002 - 2005 Explorers 1
T Troubled 2003 Explorer Sport Stock 2002 - 2005 Explorers 4
H 2003 Explorer Check Gauge light intermittent Stock 2002 - 2005 Explorers 1
B 2003 Explorer Sport 129k keeps dying, but restarts Stock 2002 - 2005 Explorers 6
B 2003 Explorer 5r55w transmission problems Stock 2002 - 2005 Explorers 2
C 2003 Ford Explorer Blinker Problems Stock 2002 - 2005 Explorers 1
S 2003 Ford Explorer Back hatch does not close. Stock 2002 - 2005 Explorers 4
C 2003 Ford Explorer Question's on fluids Stock 2002 - 2005 Explorers 37
J Transmission fluid level on 2003 Explorer? Stock 2002 - 2005 Explorers 3
Similar threads
