2003 explorer front camber
Tom N
sarasota,Fl
2003 Explorer XLT V8 4X4
I replaced the front upper control arms, lower ball joints and sway bar end links recently on my 2003 explorer (4.6l 4x4 )
Front tires are now wearing out on the outer edge like the front camber is off. Too much positive camber it looks like.
Now according to my research and a local alignment place you can't adjust front camber on these. So wtf do I do to fix this or what could I have done wrong in installing these parts?
Thanks for reading.
Mr Dubya
Elite Wannabe Explorer
Boston, Massachusetts
'03 Explorer Ltd. 4.6L V8
To adjust front camber, the lock shims must be removed and replaced with heavy duty washers, or purchase a camber alignment kit from Moog. (I have the set and like it).
The lock shims are located on the underside of the frame flange where the control arm studs pass through downwards. Run a few thread searches, I've posted on this particular subject multiple times, pics and diagrams included.
-Dubya
J Thumping in front end 2003 explorer Stock 2002 - 2005 Explorers 1
X 2003 ut explorer front indicator bulbs/globes australian model Stock 2002 - 2005 Explorers 2
H 2003 Ford Explorer Front Wheel Bearings - OEW or Aftermarket Stock 2002 - 2005 Explorers 5
D explorer 2003 guuruu sound from the front bottom Stock 2002 - 2005 Explorers 9
M 2003 Ford Explorer 4.0L 6 Cyl front end noise! HELP PLEASE!!!! Stock 2002 - 2005 Explorers 4
H 2003 Explorer Front End Popping Noise Stock 2002 - 2005 Explorers 2
L 2003 Explorer front hub assembley Stock 2002 - 2005 Explorers 3
C 2003 Explorer. Front axle seal replacement. Stock 2002 - 2005 Explorers 4
J need to remove and replace front wrap on 2003 Explorer limited Stock 2002 - 2005 Explorers 4
T How to replace the front wheel bearings on a 2003 Ford Explorer XLT. Stock 2002 - 2005 Explorers 11
J Front Brake Pads Replacement on 2003 Ford Explorer Stock 2002 - 2005 Explorers 4
E 5r55s 2003 explorer year interchange Stock 2002 - 2005 Explorers 1
S 2003 Ford explorer xlt quarter window glass Stock 2002 - 2005 Explorers 0
S 2003 ford explorer charing issue fusable link replacement? Stock 2002 - 2005 Explorers 1
G OEM electric fan on 2003 explorer sport Stock 2002 - 2005 Explorers 1
C 2003 Engine Swap To 2005 Ford Explorer Swap Stock 2002 - 2005 Explorers 5
S Hi im shawn trying to figure out the rumbling sound from breather box 2003 ford explorer xlt Stock 2002 - 2005 Explorers 2
W 2003 Ford explorer misfire Stock 2002 - 2005 Explorers 1
P 2003 Ford Explorer auto trans Stock 2002 - 2005 Explorers 2
F 2003 explorer won’t start Stock 2002 - 2005 Explorers 4
G 2003 Explorer sport 2dr 4wd Leaf spring Stock 2002 - 2005 Explorers 3
A Advice on Transmission, possible failure - 2003 Explorer 4.6 L V8 Stock 2002 - 2005 Explorers 12
J 2003 ford explorer xlt windows not working Stock 2002 - 2005 Explorers 4
M Is there a market for a 2003 Explorer? Stock 2002 - 2005 Explorers 3
2 Please Help - 2003 Ford Explorer Won't Start Stock 2002 - 2005 Explorers 5
D 2003 Explorer Eddie Bauer Aftermarket parts Stock 2002 - 2005 Explorers 1
0 2003 Explorer XLT V6 Rear End Stock 2002 - 2005 Explorers 4
M 2003 explorer 4.6l exhaust leak Stock 2002 - 2005 Explorers 0
S 2003 ford explorer for overheating Stock 2002 - 2005 Explorers 8
S 2003 Explorer Gear Shift Indicator Broken Stock 2002 - 2005 Explorers 4
J Vacuum issues with 2003 Explorer (K Motor Flex Fuel) Stock 2002 - 2005 Explorers 0
W swapping a 2004 explorer transmission in a 2003 Stock 2002 - 2005 Explorers 2
D Electrical Issue to Starter 2003 Ford Explorer Stock 2002 - 2005 Explorers 4
F 2003 Explorer squeal with right turns only (sounds like brakes) Stock 2002 - 2005 Explorers 22
B 2003 Explorer with DTC P1780 & P0775 & O/D flashing. Stock 2002 - 2005 Explorers 23
0 2003 Explorer XLT Blend Door Change-out Stock 2002 - 2005 Explorers 3
E 2004 Explorer (2003 SOHC) "death rattle" Stock 2002 - 2005 Explorers 28
L Wiring Diagram 2003 Explorer (Wiring around steering column) Stock 2002 - 2005 Explorers 0
L 2003 Ford Explorer/Remove and Replace Steering Column-HELP Stock 2002 - 2005 Explorers 1
R 2003 Ford Explorer ignition wiring diagram. Stock 2002 - 2005 Explorers 0
J 2003 Explorer coolant hoses Stock 2002 - 2005 Explorers 1
J Replacing a 2003 explorer radiator, nightmare! Stock 2002 - 2005 Explorers 2
E What were the rear end ratios on 2003 Explorer with 4.6 v8 Stock 2002 - 2005 Explorers 3
2 2003 Ford Explorer Heated/Memory Seats Problem Stock 2002 - 2005 Explorers 1
F 2003 Explorer 4.0 spark plugs Stock 2002 - 2005 Explorers 40
R 2003 Explorer XLT won't move Stock 2002 - 2005 Explorers 5
S 2003 Explorer Sport Trac Coolant Leak Stock 2002 - 2005 Explorers 4
D 2003 Explorer Stock 2002 - 2005 Explorers 1
A 2003 Explorer Crank Issue Stock 2002 - 2005 Explorers 1
T Troubled 2003 Explorer Sport Stock 2002 - 2005 Explorers 4
Similar threads
