2003 Ford Explore fuel pump not engaged
Dredus
St. Louis, Missouri
2003 Ford Explore
Have replaced almost everything I can think of and will not start
MakinJeepsWeep!
Polk County Texas
96 Explorer 5.0L AWD
Callsign
Big Red
Can we get some more information? What motor, wont crank, cant hear fuel pump run ect ect?
hondaslave1342
Chattanooga
2005 Ford Sport Trac XLT
Did you check the enertia switch under passenger glove box? If it's tripped the fuel pump will turn on
Dredus
St. Louis, Missouri
2003 Ford Explore
Have replaced twice thinking the first was damaged when bought
MakinJeepsWeep!
Polk County Texas
Callsign
Big Red
What about fuel pump relay under hood? Can swap with ac relay for testing.
Dredus
St. Louis, Missouri
2003 Ford Explore
Can not Hear fuel pump have replaced pump twice. Spark plugs changed. Battery cables Throttlebody and more
MakinJeepsWeep!
Polk County Texas
Callsign
Big Red
So the problem is indeed your fuel pump is not kicking on correct? Everything else works as it should? All the dings and lights come on it rolls over when cranking? Does it even try to spit at you or does nothing but roll over?
Dredus
St. Louis, Missouri
2003 Ford Explore
Yes en
Yes the
yes it turns but you don’t hear the two second hum for the fuel pump
MakinJeepsWeep!
Polk County Texas
Callsign
Big Red
Well if you have already done the relays and the switch, the only things left is wiring and the pump itself. Bout the only things left to check. You could hook power to the pump direct to test it.
Dredus
St. Louis, Missouri
2003 Ford Explore
Have bought and wired two fuel pumps wiring is done but not engaging
Dredus
St. Louis, Missouri
2003 Ford Explore
I'd start looking for a burnt connector
I’ve searched nothing looks burnt.
When it stopped over a year ago I was at a red light when I moved on green accelerator didn’t go fast and with in minutes lost power
donalds
Location
Stem
Nc
1999 ford explorer sohc
Next to the gas tank in the frame rail
May be one there
donalds
Location
Stem
Nc
Are you referring
Are you referring to one on the fuel pump
No but follow that wire harness back should be one
Mine is in front of the gas tank
That connector runs everything on the back of the truck basically lights ect.
