michigan jason
- June 27, 2014
- Metro Detroit
- '10 Fusion '03 Navigator
Ok, I have read many other threads on here and little bits of each of them seem to pertain to my problem. I am starting a new one because I have done many of the things mentioned across many threads already here.
Please help me fellas, I am at wits end!
I have a 2003 ford explorer 4.0l v6 4x4. Since we bought it, the rear end had the famous ford howl that all explorers have (it seems like) Mechanic said it was a recall blah blah, never addressed it, and it is still there.
Recently I noticed more and more noise and realized that the front end is making noises as well. Rubbing, howling, grinding etc. Took that car to midas, they said I needed the following. Also recommended brakes. We had them complete all of the work BTW. So all of the following is new.
Both front drivers and passenger side wheel bearing/hub assembly
Upper and lower ball joints (front both sides)
Sway bar links (both sides) (old ones were simply hanging there)
Front brakes, (new ceramic pads and rotors both sides)
(Mechanic said the bearing going into the transfer case was fine)
(Mechanic also stated he disconnected the 4x4 and the problem was still the same)
Long story short, the noise is still there and we are lost. The mechanic actually ate the cost for the passenger wheel bearing just trying to figure out the problem for us.
To attempt to describe the noise, it seems to be present as soon as the vehicle is moving, gets more violent (loud) when cranking the wheel either left or right.
Mechanic says he is pretty sure it is the differential but honestly he seems as lost as we are.
Please someone chime in and shed some light on this dark situation!
KCCO
KCCO
