Israel Palomar
- July 28, 2018
- San Antonio
- 2003 Ford Explorer, V6
Needing a different angle on this issue. I’ve replaced everything but the heater core and the two heater lines on this cooling system. Back information is the radiator just went out a month ago. And the entire system was never flushed or maintained since I got my hands on it. Radiator was full of sand and cinnamon looking debri when I drained the system. First it was Termostat, then T coupling, finally radiator. I put in a new water pump when installing the new radiator and all new hoses since the old ones had the baked on sand inside all of the hoses. No matter the scrub, it wouldn’t come off. After install I did a hard system flush with new hoses and reservoir tank and a new thermostat housing. The fan is perfect. No cracks or missing blades and the entire system is sealed. Any ideas on what this could be? I’ve replaced everything but the heater core like I said. I filled the system with antifreeze before I put the thermostat in so the system wouldn’t have any air in it then as I put everything together I filled it up as I went along. Fluid level is great. Don’t understand why it gets hot when idling.
