tper94
- August 14, 2019
- 2003 Ford Explorer XLT
I have a 2003 Explorer XLT with a 4.0 v6 4x4. I’ve been trying to figure this out for months now.
Every time I drive the car from C it briefly overheats. The temp gauge rises like normal, but when it reaches operational temp the gauge spikes into the red for about 2-5 seconds and falls back down to normal temp. The rise and fall to and from red lasts about 3 seconds each. From that point on it drives as it should. I could run it out of gas if I wanted. (For future reference. This paragraph is “the thing” haha)
It loses fluid and I have to add some at least every month or two, so not quickly. I don’t check every time I drive, but I believe it’s mostly lost through the reservoir cap. The system seems to not have any signs of leaking elsewhere. I flushed the system and refilled at one point using a vacuum tool to remove all the air and it held the vacuum steady. No signs of weeping from the water pump as it’s pumping properly.
I most recently burped the system two days ago with the nose up in the air and the tires about a foot and a half off the ground. That appeared to solve the problem, but the issue came back today. Test drove it yesterday from C and it was fine. Today it did “the thing.” Drove it about 25 miles the rest of the way home and it did great.
No colored exhaust, or milky colored oil so I’m not leaning toward a blown head gasket. I found some threads on here talking about the reservoir cap (no radiator cap on this one). Could it be holding pressure instead of releasing it forcing an air pocket to develop somewhere?
Parts I have replaced: radiator, thermostat (twice. One aftermarket. Currently an OEM), and thermostat housing (cracked))
