Jfranzo
- May 11, 2019
- Jacksonville
- 2003 Ford Explorer xls
Long time lurker here. My 215k mile explorer just developed the death rattle. It won't rev over 4k rpm. At about 3k I can hear the front (left) chain rattling. It has codes for cylinder 4, 5 and 6 misfire.
I understand the this is an engine out procedure and I'm preparing to do the job. I've found some helpfull threads on this forum and I plan to update my progress here.
I recently did a similar job on my 2011 Expedition successfully. Though I was able to do it without removing the engine because both chains are in the front. If you are interested in a good read, check it out....
Loss of power, no code.
A couple questions I haven't found a clear answer to....
* Since it's just the left timing chain rattling should I consider just repairing that one so I don't have to pull the engine?
* Is the Cloyes kit the best option or should I look for genuine Ford parts?
* Is it best to pull the engine and transmission out together or separate them and leave the trans in place?
* How can I find out if my engine has the balance shaft before I order the parts? (2003 Explorer xls 4.0)
* What upgrades should I be sure to do while I'm in there to prevent this from happening again? Tensioners, guides, oil pump, ect...
I'm sure I'll have more questions that will require the experience on this forum and I hope to pay it forward after my repair is successful.
Thanks!
Thanks!
