AmphiPilot
- December 25, 2006
- Canton, Michigan
- 2003 Sport 4wd
Greetings: I'm a new member and have a problem with my recently purchased 2003 Sport 4wd. I purchased it from an auction and therefore never drove it. I now find that I have several problems that all seem to point in one direction.
The 4wd does not work. It will engage in 4wd HIGH, but then will not disengage. I had to remove the battery cable to reset it and it's now in 2wd mode again.
The air circulation system only works in defroster mode. I believe all systems default to defrost when there's a problem to prevent potential windshield icing.
The cruise control does not work.
Everything seems to indicate a bad fuse (F2.16 in the Central Junction Box), but the fuse is OK. Has anyone out there experienced a similar problem? Please help!
I'll check this forum later, but if you're willing to help by also sending email, my address is: AmphicarPilot@aol.com
Thank you.
Thank you.
