dustin502
- March 4, 2016
- 2003 Ford Explorer Sport
My wifes sport trac started running rough and the check engine light came on. I scanned it and it had two codes, P0305 and P0316. I put new plugs and wires on it and I'm still getting the same codes. I swapped the plugs from #5 & 6 with the same results. Then I swapped the wires from # 5 & 6 with no improvement. Installed a new coil pack and still have the same codes. I checked the compression on #5 and it has 150 psi. Then I figured it had to be the injector so I removed the intake manifold and replaced the #5 injector and installed new manifold gaskets. And of course, I still have the same problem! Can anyone help me out? I am at my wits end!
