MidnightRebel07
- March 6, 2010
- Pittsburgh, Pa.
- 2003 Explorer Sport Trac
MidnightRebel07's Sport Trac SAS, 351w Build on 37's
I've been talking for years about doing this and since the transmission is on it's way out enough to where I can't drive it a long distance, the fan clutch died (can't drive it without fan) I parked it.
I started tearing everything from the rear suspension to do the SOA. finished that yesterday (for the most part). Perches are tacked in (will finish welding them on with the Miller 252 at my custom truck clubs garage once I get everything mocked into place and a space opens up). Shocks are bolted into the top bolt hole for the sway bar (sway bar is removed). I cut the shock mounts off of the spring plates and will weld them onto the top of the axle later. I still need to get longer stainless braided hoses for the main rear brake line.
I now have the front jacked up sitting on jack stands so I can start cutting off the front suspension and engine crossmember. Hopefully if the weather permits this week for a couple hours in the mornings before work I can cut all that out.
I'll be starting a SAS, SOA, 351w, C6, 1356 manual transfer case thread sometime soon when I have time but for now I'll just add info here.
