2003 XLT V8 with tranny problem
Tom N
sarasota,Fl
2003 Explorer XLT V8 4X4
I have a 2003 XLT V8 4x4 with 80k on it and the O/D light is flashing. It shifts into 2nd very high in the rpm range and wont go into od at all. So i had the code pulled and is said something to the effect of needing to change the shift solenoid. So I did that and it still acts the same. Pulled the code again and it says 2nd gear ratio out of range??? Any idea what the problem could be.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Tom N
sarasota,Fl
I dont remember the code number. But it said "2nd gear ratio out of range"
mechanix
Got beer?!?!?!
Springport, Michigan
91 xlt & 93 xlt
I have a 2003 XLT V8 4x4 with 80k on it and the O/D light is flashing. It shifts into 2nd very high in the rpm range and wont go into od. so i had the code pulled and is said something to the effect of needing to change the shift solenoid. So I did that and it still acts the same. Pulled the code again and it says 2nd gear ratio out of range??? Any idea what the problem could be.
Is this is the 4r70w trans? If so I would take a peak at the 1-2 shift accumulator. They are good for breaking the spring and causing high rpm and very harsh shifting from 1 to 2.
Eric
Tom N
sarasota,Fl
I believe its the 5R55W.
I think it is either the O/D servo or the band broke.
If the band broke how would that effect 2nd gear?
Anyone know.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Tom N
sarasota,Fl
The servo engages the band to grab the drum to get you into second gear.
So by my description of the problem do you think it is more likely that the OD servo is bad or the band is broke.
Thanks for your help.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Tom N
sarasota,Fl
Dropped the pan when the solenoid pack was replaced thinking it was the problem. Didn't see and pieces of metal. How much should I adjust the band. Like one full turn and should I be going clock wise.
If the band was broke would the truck still go into 2 gear?
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Tom N
sarasota,Fl
Should you be able to tell if the band is broken by adjusting on it.
What should I expect to see happen if I adjust it in some?
Just trying to see if there is a way to narrow it down better between it being a broken band or a bad OD servo before taking it apart.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Tom N
sarasota,Fl
See if the band could be adjusted by turning the stud. If it keeps turning, then most likely the band is broken, and the parts are sitting inside of the pan.
Alright I`ll try that.
I already took the pan off though and there weren't any parts in it.
K 2003 ford explorer sport xlt slipping in drive/reverse Transmissions & Transfer Cases 1
G 2003 explorer 4 door xlt sport Transmissions & Transfer Cases 0
J 2003 Explorer XLT 4X4 V6 Transmission Problem Transmissions & Transfer Cases 2
O 2003 Explorer XLT 4WD Transfer Case Module & Electric Motor Shifter failure Transmissions & Transfer Cases 3
T HELP w/ changing 2003 XLT Rear Differential Fluid Transmissions & Transfer Cases 19
D 2003 MERCURY MOUNTAINEER Transmissions & Transfer Cases 3
08EddieCA 2008 Torque Converter compatible with 2003 Automatic Trans Transmissions & Transfer Cases 2
D 2003 5r55s with 247k is tired... Transmissions & Transfer Cases 7
M 2003 EXP in 4x4 high after oil change Transmissions & Transfer Cases 1
A 2003 Tranmission Wiring Harness?? Transmissions & Transfer Cases 1
J 2003 Explorer Transmission Problem AFTER replacing solenoid Transmissions & Transfer Cases 1
M 2003 Limited with transmission codes. Transmissions & Transfer Cases 4
R 2003 Explorer Limited V8 Transmission Transmissions & Transfer Cases 4
I 2003 Ranger- Transmission won't shift! Transmissions & Transfer Cases 8
M 2003 4.0 V6 - Catastrophic transmission failure at 180,000 miles. Transmissions & Transfer Cases 0
O 2003 Ford Explorer Trans and Solenoid Transmissions & Transfer Cases 1
K 2003 Explorer Transmission troubles Transmissions & Transfer Cases 0
C 2003 transfer case motor issue or control module Transmissions & Transfer Cases 1
B 2003 LSD - Pinion Seal Blew On Interstate - Rear Diff Ruined? Transmissions & Transfer Cases 2
K Bad Transmission or Bad Solenoid B? 2003 Explorer Transmissions & Transfer Cases 0
D 2003 Ford Explorer Transmission Problems Transmissions & Transfer Cases 4
R 2003 Explorer Flashing OD light Transmissions & Transfer Cases 1
S 2003 Explorer Sport with 5r55e, No 3rd Gear Transmissions & Transfer Cases 2
K 2003 - OD light blink Transmissions & Transfer Cases 1
J 2003 ford explorer clutch Transmissions & Transfer Cases 1
S 2003 mountaineer lost reverse! Transmissions & Transfer Cases 1
M 2003 Explorer 4.0 AWD Transmissions & Transfer Cases 1
B 2003 Mercury Mountaineer Transmission Issues Transmissions & Transfer Cases 10
M 2003 explorer LTD stock torque converter specs Transmissions & Transfer Cases 0
R Will a 2008 2.3ltr 2wd ranger automatic transmission, fit a 2003 3.0 2wd Mazda b-3000 Transmissions & Transfer Cases 1
R Can a 5r55s be put in place of 5r44e 2003 Mazda b3000 2wd>>(want select shift feature Transmissions & Transfer Cases 1
S 2003 Explorer Limited 4.6L Shifting Issues Transmissions & Transfer Cases 7
M 2003 sporttrac trans issue Transmissions & Transfer Cases 1
N 2003 trans problem. Transmissions & Transfer Cases 0
S 5R55E in 2003 Ford Explorer Sport Transmissions & Transfer Cases 1
R 2003 mountaineer tranny issues Transmissions & Transfer Cases 5
F 2001-2003 Explorer Sports with the M5OD Transmissions & Transfer Cases 0
U 2003 8.8 ls swap into 95 ranger 2 wd Transmissions & Transfer Cases 1
D My 2003 Explorer 4X4 lost reverse. Transmissions & Transfer Cases 2
W 2003 Ford Explorer. Transmission issue. Transmissions & Transfer Cases 5
D 4wd acturator switch location on 2003 Explorer Transmissions & Transfer Cases 2
M 2003 explorer shifts in and out of OD Transmissions & Transfer Cases 2
J 2003 explore transfer case PM Transmissions & Transfer Cases 1
J Problem with 2003 transmission. Transmissions & Transfer Cases 4
T 2003 ranger no reverse and o/d button doesnt work Transmissions & Transfer Cases 0
C Wanted Front Differential 2003 3.55 Transmissions & Transfer Cases 0
E 2003 Explorer. Transmission fluid check. Transmissions & Transfer Cases 1
0 2003 f150 Transmissions & Transfer Cases 1
F 2003 Ranger with a transmission problem. Transmissions & Transfer Cases 2
K I'm trying to replace the automatic transmission on my 2003 Ford Ranger. Transmissions & Transfer Cases 4
Similar threads
