1Aauto
EF Vendor
- April 1, 2009
- mass
- 92 explorer
VISIT US HERE FOR GREAT PRICES 2004-2005 Ford Explorer Front Shock and Spring Assembly Pair (Monroe Quick-Strut)
FREE SHIPPING ON ALL ORDERS IN THE LOWER 48 STATES ON ALL ORDERS!!
MONROE QUICK-STRUT® PAIR 171398
These are new MONROE shock and spring assemblies.
Specifications:
Quantity: (2) Shock Assemblies
Side: Both LH (Driver Side) & RH (Passenger Side)
Vehicle Type: All
Engine Size: All
Quick and easy... remove and replace one piece! No need to take apart entire assembly. No need to compress coil springs. Do the complete job right the first time. Enhances the handling, safety and performance of your vehicle.
Each includes the following preassembled components :
Upper Mount
Upper Spring Isolator
Upper Spring Seat
Boot Kit
Lower Spring Isolator
Premium Shock
The revolutionary Monroe Quick-Strut unit is the first complete, ready-to-install replacement strut assembly available! Monroe Quick-Strut units include all the components required for strut replacement in a single, fully-assembled unit. They feature preassembled replacement upper mount, upper and lower spring isolators, upper spring seat, coil spring, boot kit, and a premium strut. This breakthrough design saves on installation time by eliminating having to disassemble components and compress the coil spring prior to installation. Each Quick-Strut assembly features application-engineered valving to optimize each vehicle's unique ride and handling characteristics.
In the past, replacing struts required specialized tools to compress, remove and transfer the spring. Our new strut and spring assemblies make this job much simpler for the do it yourself mechanic. This part comes preassembled. Jack up and support the vehicle with jack stands. Remove the wheel. Unbolt the top mounts and the bottom from the suspension and replace the whole unit. The large bottom bolts usually require an impact wrench and socket for removal. When reassembling, be sure to torque all nuts and bolts to their proper specifications. Do not use impact tools when reassembling.
VEHICLE FIT
2004-2005 Mercury Mountaineer Front Shock and Spring Assembly Pair (Monroe Quick-Strut)
Specifications:
Vehicle Type: All
Engine Size: All
Upper Mount
Upper Spring Seat
Boot Kit
Premium Shock
VEHICLE FIT
