Floridaexplorer43
- September 15, 2018
- Tallahassee, FL
- 2003 4wd 4 0
recently bought a 2004 Explorer with 160000 miles. I no longer have my 2003 Explorer.
I immediately had to have both wheel bearings in back replaced and was told the cv axles on passenger side had recently been changed before I bought it. I have a abs code for passenger front and feel like front hubs will be changed next.
I have Eddie Bauer edition rear wheel drive independent suspension with cv axles in rear.
I’m hearing a grinding sound like I have to be cautious with acceleration bc it sounds like a wheel is spinning or grinding sound like a stuck caliper or rubbing brake sound.
why are all bearings bad at 160000 miles??Buying online I can buy two cheaper than one at Auto Zone.
one rear bearing install, a shop used a hammer and torch not a press to remove and or install bearing.
4.0
Rear wheel drive 2wd
4.0
