Blazen8899
- June 12, 2016
- Roanoke
- 2004 Ford explorer xlt
Okay, so I'm at a total loss, hopefully somebody can shed some light on this situation.... So I bought this explorer non running from a private individual, they replaced the engine out of another 2004 explorer 4.0 and they could never get it running, their mechanic said the timing jumped a tooth which it did, I had my dad check it and the engine was low on compression (bent or burnt valves) and sure enough was out of time, we tried and tried to get this engine running but it just kept jumping time, so instead of replacing all of the timing components in that engine which we also didn't know the mileage on, we went and got the original engine from the people I bought it from that busted a timing chain tensioner... we replaced all the tensioners, guides, spark plugs, coil pack, and crank sensor... when my dad put the engine in it cranked over, ran rough for about 2 seconds and shut off, back to cranking but not starting.... fuel pressure is good, spark is good, and it's getting air... it also will not start on starting fluid, PATS system light comes on and goes off after 3 seconds like it's supposed to.... however when I was cranking on it the other day the small ground wire going from the negative battery terminal to the front of the car (above the headlight?) Started smoking and got really hot to the touch, hot enough I could only touch it for a fraction of a second... but it only did this after extensive cranking 1+ minutes.... any ideas are greatly appreciated, like I've said, I'm at a loss. It's a 2004 Ford explorer xlt 4.0 flex fuel
