2004 Ford Explorer XLS sporadic misfire on all cylinders | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Kentucky Reign
Glendale, Ky
2004 Ford Explorer
Please someone help! It only does this at Idle. My mechanic has checked/changed fuel trim, plugs, coil pack, wires, timing chain, fuel pressure, fuel filter, etc..the basic stuff you would think of. I took it to the dealer today and had the PCM flashed with the latest software as he thought that may help. It didnt. There are no codes, I've only noticed because I'm in the car 7 hrs a day driving and noticed it shaking more than usual at red lights. I'm thinkiing maybe the PCM may be going but I'd like some other opinions. It was replaced 8 years ago right after it was bought. I have no other idea what it may be. Crankshaft sensor? Cam Sensor? This particular model doesn't have an IAC. I dont know but I am stumped
pet575
Kansas City, MO
2004 Limited
Might be as simple as a vacuum leak before you go getting into timing chains, cam/crankshaft sensors, etc. Have you had someone check it out by spraying water or brake fluid on the vacuum lines with it running to see if that changes anything?
