2004 ford explorer | Ford Explorer Forums - Serious Explorations
2004 ford explorer
STR
SOUTH TEXAS
2004 ford explorer
Hi i am new to this form and having trouble with my rear wipers and both washers. I have checked fuses # 4,8,15,19,under dash all good. Fuses 23 & 30 under hood both good. Changed turn signal switch. I have no power going to pump.when i turn rear wipers on it clicks sometimes in back. Thanks for any help . I do not know what else to look for
thanks
Check the wire bundle between the body and the door.
Over time they fatigue and break from repeated flexing from door open/close cycles.
Another common symptom is the door ajar light staying on.
Your front washer is unrelated to what's going on in the rear....probably a bad pump up front.
Washer
Thanks i check the wires in the door, but i do not have power at the pump.
Thanks
Just to let others know, i check with a ford tech and he said a bad rear motor will stop the washer pump from working, and he was right.fixed that and everything works.;)
