pet575
- June 11, 2008
- Kansas City, MO
- 2004 Limited
"Service Engine Soon" light came on yesterday so I took it to O'Reilly and had them read the codes. Got P0308 Cylinder 8 misfire.
Understanding is that several things could cause this, varying from a bad plug to a bad coil, bad wire, clogged/bad injector, bad cat converter.
My plan is to first swap the coil on Cylinder 8 (driver's side, closest to firewall) with the coil on Cylinder 7 and see if the code then moves to Cylinder 7. If it does, I know it is the coil. If it doesn't, I know the problem is either the plug, the wire, or the injector. No rotten egg smell or anything to indicate exhaust issue.
Additional thoughts or does that pretty well cover things? I'm at 197K so I guess I'm due to change all the plugs regardless.
