2004 mountaineer exhaust question | Ford Explorer Forums - Serious Explorations
MattB2091
2004 Mercury Mountaineer
For Off-road Use Only!!
I want to know about the catalytic converters on this. It's a 4.6, I see what appears to be 2 cats then after the 2 pipes meet there is another cat or resonator or something. What is it and can I remove it safely without problems. Obviously for off road. Then if I ever jump on the road I'll slap it back on. I want a good exhaust tone. Also where can I find the tailpipe for this car, it has 2 sections that join together over the rear axle. I currently have the exhaust dumping out the side
THANKS
Rockauto for your last question.
Its a cat, but an exhaust shop in Austin that recently did some work on mine says "it doesn't do much" and was willing to replace it with a weld-in pipe after material from the upstream bank 2 cat dumped a bunch of debris into the third cat, which they couldn't pull out.
Ok I'm going to take it off, does anyone know the outside diameter of the exhaust pipe that's before it. So say I cut it off and I put a adapter there to run tubing out the back what size adapter will I need. Also is my car gonna throw codes?
Thank You
Just thought I'd add this.
I didn't measure mine, but I assume 2.25".
No codes, since there are no O2 sensors downstream of that cat.
For what it's worth, I'm now getting a brief (but obnoxious) drone on spirited acceleration from stop. Almost sounds like a bad exhaust manifold gasket, but only at a given rpm/load, so I think its the exhaust. This happened after the "third cat" was removed. Makes me wonder whether its really a cat (what the shop called it), or maybe a resonator. Could it be both?
