Moving to the next issue. the cruise control, the on off button is damaged, the part is ordered, but my question is, Is the cruise control light supposed to come on during the cluster test? , key on / start test?
The switch may be the problem, (it feels like it should work) but the cruise control does not work, and the light does not come on.
Edit,
The brake cylinder switch is open with and without brakes applied, found a bad fuse for the running lights while poking around.
Does it use both the pedal, and cylinder switch for the cruise control?
Edit again,
it uses both switches, I bypassed the master cyl switch, and it works fine now, and disengages when the brake is pressed.
The light does not come on during any test, only when the cruise control is working. for future readers
Next is the bed cover, the front lock does not open the cover, and the driver's door handle is hard to open.
