Thanks for your response. There is no check engine light and no wrench light. The lights do check when key turned on - but no error lights when started. Only the seat belt warning light - if seat belt not fastened. We have checked codes....... have had a variety - have cleared codes - and currently have P0113. P0135, P0202. Scanner is OBD II - does not do ABS codes function, etc. When started it idles okay for the most part, and when Key on, Engine Off - the throttle plate moves with the accelerator pedal. When running, and you step on accelerator pedal, seems to choke out and die - not a clean cutoff. We have replaced the fuel pump, all coil packs, Mass Air Flow Sensor, air filter, fuel filter, etc. I thought it was starving when throttle plate opened, and a friend stopped by long enough to measure fuel pressure with his reader - said it was 33 - and needed to be 50 or more when running - and said we needed to replace fuel pump. So removed tank, replaced fuel pump - still same result. Have read it seems like a thousand google searches and watched hundreds of youtube videos - but nothing seems to work. Have removed negative battery cable and held to positive post for 5 minutes to try to reset PCM. Tried to get Throttle Body from junkyard 30 miles away, but was 4.0 not 4.6 liter engine. Do not know what to try next. Have tried to find Ford mechanic with advanced code reader and knowledge to point us in right direction. Have already had vehicle transported and towed twice. What should we try next?
