martin_95037
- May 30, 2015
- Morgan Hill, California
- 2005 Explorer EB 4.6 V8
Are there any technical service bulletins for front end alignment? The tires have always waired on the inside.
past pregnant history With out looking at my records
About a 18 months ago
replaced the upper control arms, lower ball joints,tire rod ends. They where trashed
replace 2 tie rod ends
About 2 or 3 months ago.
replaced the Rack and pinion with an after market rack an pinion. Replace right lower control arm ball joint due to play. Install camber caster kit.
Today. Do an oil change and see the tires are wearing on the inside, right side worse than the left side. Truck is on the rack right now.
