Dan308
- February 12, 2017
- Albuquerque
- 2002 Ford Explorer Sport
No solution to this problem. I have a 2005 Adrenaline the ABS light is always on when the key is OUT and drains battery. Truck starts and runs fine with NO ABS warning light. Turn off truck and the ABS light comes on and stays on. So far I have done the following:
Pulled every fuse 1 at a time. -Light still on
New ignition switch -light still on
new key switch and cylinder -light still on
disconnected wiring from ABS pump and started truck -light still on
Drain capacitors on PCM and reset -light still on
sent my cluster out for repair -light still on
purchased a new cluster, same model and manufactured same week -light still on
anyone seen this before?
