jmpreiks
- May 9, 2017
- 2005 Explorer XLT 4.0 4X4
Hi,
I have 2005 Explorer XLT 4.0 4WD with a 5R55S transmission that just lost 2nd gear and presumably 5th but haven't tested at that high speed. I am hoping you guys might be able to help me diagnose the issue. It has around 150k miles on it.
Background and Symptoms:
Any guidance on this would be GREATLY appreciated, my wife is due with our 3rd child in 2 weeks and we really need this car back in action. I am really hoping to not remove the tranny to fix it, but think I can pull that off if I really have to. I think any internal repairs are out of my league right now given I have a short time frame and basic tools.
The service manual says to do some diagnostic "Trans-Bench Mode" where you can send control signals and measure the results to help diagnose, but I don't have access to a tool that can do that. What electronics can I test with just home tools (i.e. a multimeter)?
Thanks in advance for any guidance or tips!
Justin
- My wife was driving one day and said it wouldn't let her drive faster than ~20mph or so (all of a sudden). It was flashing the O/D Off light and she said it said to service the transmission on the display. It hasn't flashed the light or message in my subsequent test drives. The only transmission issues prior to that were some harsh shifts into reverse, and my wife says there might have been a few delayed shifts recently but can't really remember.
- There is only one code I could read, P0775, which the service manual says is "PCB solenoid or circuit fault --- PCB functional fault — low pressure --- Incorrect shift pattern indicating mechanical or hydraulic failure of the transmission. Will turn on MIL." The MIL is NOT on.
- Torque Lite said that it was a "pending fault" and not a "logged fault", though I don't know what that means.
- I did some driving tests and manual 1st and 3rd work perfectly fine. D gets to around 20mph and falls flat when trying to shift to 2nd and then returns to 1st and keeps going in that cycle. Shifting to 2nd while driving results in really slowing down and heading toward what feels like a stall before I shift back to 3 or 1. Starting from stop in 2nd feels like the brakes are on and the car does not move.
- I bought a pressure gauge and did a line pressure test at idle and close to WOT:
- IDLE (psi)
- N: Service Manual Range: 90-120; Measured: 120-150
- R: Service Manual Range: 100-140; Measured: 240-270
- D, 3, 2, 1: Service Manual Range: 90-110; Measured: 170-180
- WOT (psi)
- R: Service Manual Range: 282-380; Measured: 360
- D, 3, 2, 1: Service Manual Range: 228-263; Measured: ~270, lots of needle bouncing
- Pressure drops to around 60-90 psi while shifting.
- IDLE (psi)
- The line pressures at idle are significantly higher than the service manual specs. Is that a concern or a clue? I have not checked the PC C pressures yet, but I'll try that tomorrow night, hopefully.
Justin
