2005 Explorer. Broken shifter, part name, availability
JasperCountyNative
2005 Explorer
This image is just like the broken column shift on my daughter's 2005 Explorer.
I know I can get the alloy part that links to the shift lever aftermarket, but the brass piece on the back side with the hard plastic ball is also damaged. Ford doesn't even seem to have a name for this part. My only option so far is to buy an entire steering column to obtain this one little part. Any suggestions on where to find one? Any idea what this is called?
Thanks in advance.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
silverfox103
Littleton NH & St. Simons GA
2003 Lincoln Aviator
I'm sure this is nothing that you haven't thought of, but every junkyard that I have been to, has had an abundance of Ford Explorers. Go to a "you pick" yard and take it off yourself.
Good Luck
Tom
JasperCountyNative
2005 Explorer
Good Luck
Tom
Thanks Tom,
I called one near here this morning. They have an Explorer and want $50 for the steering column, but I guess I didn't ask specifically about that one part. Maybe they will sell the column, piece by piece. Worth a try.
silverfox103
In all honesty that's probably a fair price. I'm assuming they will take it off. I had a similar problem with my Aviator last year. Floor shift had a rod or linkage break. I was out of town, so I had it towed to a tranny shop. They fixed it the next day, but it was somewhere around $300 to $400. I knew I got stung, but I got it fixed and was on my way. That included fluid and filter change.
Tom
JasperCountyNative
2005 Explorer
Tom
This is one of those 'you pull it' places. Regardless, it looks like my only option. Seems like someone somewhere online would have one for sale though, lol.
4_U_2_NV
Upstate South Carolina
02 Explorer XLT 4.0
I've got a 02 xlt and mines broke also. I've been driving it for 10 months now with out a shifter. But if I'm not mistaken they don't sale just that part. You have to buy a completely new column. I know it doesnt cost that much to buy a column and pull it at the junkyard I just really haven't had time and haven't felt like screwing with all that when shifting it with the linkage has/is working just fine for me. The only downfall to that is I can't switch overdrive on and off.
JasperCountyNative
2005 Explorer
I went to a 'pick n pull' yesterday and took out a steering column. That was fun, lol. Now I just need to cut the retaining flange on the backside of the piece and remove it. The shifter part that is broken on mine is intact on the salvage column. I would like to re-use both pieces, but I don't know if I can use a split ring (as included on the aftermarket part) to re-install the salvage shifter into my truck.
360cid
Snohomish Washington
2004 Explorer XLT
Dorman part #905-104. Any auto parts store should be able to easily get one for you without the need to get an entire steering column!
JasperCountyNative
2005 Explorer
Unfortunately, Dorman doesn't make that brass lever. It is considered an 'unserviceable' part. The video says that part will have to be reused.
JasperCountyNative
2005 Explorer
All fixed! Unfortunately, I was unable to reuse the aluminum shifter from the salvaged column. I thought I could buy a 1/2 inch snap ring and replace the flange that holds on the brass lever with it, but there was not a sufficient groove to hold the snap ring. I bought a $39 Dorman shifter kit (snap ring included) and used it with the salvaged brass lever. Works like a charm.
N 2005 Explorer broken rear window hinge- recall? Stock 2002 - 2005 Explorers 7
J Fixing Overhead Console with broken tabs on 2005 Explorer Stock 2002 - 2005 Explorers 1
L 2005 Explorer XLT Sport Driver's Power Seat broken Stock 2002 - 2005 Explorers 1
R 2005 Explorer - Cigarette Lighters Broken Stock 2002 - 2005 Explorers 0
V 2005 Explorer pdf manual? Stock 2002 - 2005 Explorers 2
M 2005 ford explorer remote Stock 2002 - 2005 Explorers 3
Y Custom door chime for 2005 Explorer Stock 2002 - 2005 Explorers 4
C 2003 Engine Swap To 2005 Ford Explorer Swap Stock 2002 - 2005 Explorers 5
A 2005 Explorer V6 4.0 Timing Chain Question Stock 2002 - 2005 Explorers 2
M transmission wiring harness 2005 explorer xlt 4.0l 4x4 Stock 2002 - 2005 Explorers 0
J 2005 Explorer CB Instal Stock 2002 - 2005 Explorers 1
R 2005 Explorer 4.6 P1237 and P0191 Fuel Pump Stock 2002 - 2005 Explorers 0
B 2005 Explorer shifter loose Stock 2002 - 2005 Explorers 5
M 2005 ford explorer xlt 4.0 Stock 2002 - 2005 Explorers 2
J 2005 Ford Explorer XLS 4.0 V6 issues Stock 2002 - 2005 Explorers 14
A HELP! 2005 Ford Explorer Fuel Pump ???? Stock 2002 - 2005 Explorers 15
E explorer 2005 aut transmission Stock 2002 - 2005 Explorers 0
J 2005 Ford explorer Stock 2002 - 2005 Explorers 0
E No brakes after changing front brake caliper of 2005 ford explorer Stock 2002 - 2005 Explorers 5
J Transmission slip 2005 Explorer Stock 2002 - 2005 Explorers 15
F Cranks and Won't start? Flooded and Fuel in Oil? 2005 Ford Explorer 4.0? Stock 2002 - 2005 Explorers 7
A 2005 Explorer Cruise Control Issue (Need advice) Stock 2002 - 2005 Explorers 18
R 2005 Explorer XLT 4.0 Stock 2002 - 2005 Explorers 2
B 2005 Explorer Crank No Start - Help Appreciated Stock 2002 - 2005 Explorers 4
C 2005 Explorer 4.0 engine noise Stock 2002 - 2005 Explorers 1
N Fuel tank needed for my 2005 Explorer Stock 2002 - 2005 Explorers 9
L 2005 Ford Explorer Washer Fluid Pump Stock 2002 - 2005 Explorers 0
1 2005 explorer help Stock 2002 - 2005 Explorers 0
B Hello all from MD. 2005 Explorer 4.0litre sohc, Limited Stock 2002 - 2005 Explorers 4
T 2005 Explorer GSM add on? Stock 2002 - 2005 Explorers 10
M 2005 Explorer 211xxx Miles. left and right low beams wont turn on. Stock 2002 - 2005 Explorers 4
J 2005 Explorer 20" Rim Specs Stock 2002 - 2005 Explorers 0
O 2005 Explorer driver side head Stock 2002 - 2005 Explorers 1
S 2005 Explorer - Engine Rebuild - No compression Stock 2002 - 2005 Explorers 1
G How do I get to the top of my fuse block in a 2005 Explorer Eddie Bauer Stock 2002 - 2005 Explorers 3
B 2005 explorer 4.6l W code problem Stock 2002 - 2005 Explorers 0
J 2005 explorer wiring Stock 2002 - 2005 Explorers 1
J Question about heater actuator 2005 Explorer Stock 2002 - 2005 Explorers 3
B 2005 explorer 4.6 Stock 2002 - 2005 Explorers 2
M 2005 explorer Stock 2002 - 2005 Explorers 3
G 2005 FORD EXPLORER 4X4 SHIFT ISSUES Stock 2002 - 2005 Explorers 6
F 2005 Explorer Horn Troubleshoot Stock 2002 - 2005 Explorers 3
F 2005 Ford Explorer not starting Stock 2002 - 2005 Explorers 4
B 2005 Explorer V8 Check Engine Light On After Servicing, Low Idle Stock 2002 - 2005 Explorers 2
J 2005 Ford Explorer XLT -- while driving the O/D light on the dash is steadily flashing Stock 2002 - 2005 Explorers 1
J 2005 explorer traction control issue Stock 2002 - 2005 Explorers 1
D 2005 Ford Explorer Ltd heat/ac issues-vacuum leak or blend door ? Stock 2002 - 2005 Explorers 0
W 2005 4wd Explorer that needs sway bar linkages replaced, money is very tight. Stock 2002 - 2005 Explorers 3
D 2005 Explorer XLT Stock 2002 - 2005 Explorers 2
K 2005 Ford Explorer advancetrac with V6 4.0 L sohc engine will start and cut right off broke TP sens Stock 2002 - 2005 Explorers 0
Similar threads
