23wyatt
- July 18, 2012
- Nacogdoches, TX
- 2001 Exp ST & 2005 Exp
If my water pump pulley is squeaking/chirping, does that mean the pump is about to go out?
I have a new serpentine belt on, and I replaced the idler pulley and the belt tensioner pulley already. Both of those needed to be replaced, but it only reduced the squeaking....
If I put a little liquid lube around the bearing of the water pump pulley behind the fan the squeak disappears for awhile, but doesn't go away.
So Explorer experts......how bad is this? Should I start saving? Or are my worries in vain?
