Hey Swshawaii - I did what you suggested. I soaked all the doors with WD40 and let if sit over night. Did it again in the morning before leaving for work. I sprayed them with a white grease that evening (3 or 4 days ago). Today I took the drivers door apart. I checked the wiring in the boot between the door and the frame and nothing is broken. I checked each one at least twice. I checked all the other connections in the door. The mirrors, windows and keyless entry all work fine. Just the power door lock buttons inside. When I hit the button I get nothing - no sound or even a twitch of the locks. I disconnected everything and cleaned all the connections. Still nothing. Something else is going on because my factory autostart doesn't work either. It turns everything on, does a couple of flashes and then seems to turn off, then it will do it all over again several times. Not sure how many times it would do this becuase I started it with the key after 2 or 3 - I didn't want something else to mess up. When I had my door apart and the driver side kick plate and fuse panel I cound 2 brown wires going to a little push button switch connected to a couple of red wires. Any idea what this is? I pushed it with the truck running and it didn't do anything.
I know this is long winded.....I'm lost. I check my fuses and relays as well. All looked fine. How do you know if a relay is bad when you can't see inside like a fuse? Just switch them around?
Any suggestions? Thanks for your input it is appreciated.
Doug
